996 Forum 1999-2005
Clutch is toast. Time for a clutch and LN IMSB/AOS/RMS
Old 04-27-2014 | 12:22 AM
e code's Avatar
e code
Default Clutch is toast. Time for a clutch and LN IMSB/AOS/RMS
So anyone know where I can get this done in Upstate NY? Near Albany. I am trying to keep it under $2500 if possible. Thanks!
Old 04-27-2014 | 01:56 AM
pfbz's Avatar
pfbz
That should more than cover the parts, some new high-lift jackstands, and any additional tools you might need...
Old 04-27-2014 | 05:35 AM
Arne Klinge's Avatar
Arne Klinge
I just did this.
I did LN Engineering IMS bearing, clutch, fallout bearing, preassure plate and slave sylinder. On older cars it was suggested also to change the clutch fork. Uncertain if that is still a part to replace now.
Old 04-27-2014 | 06:17 AM
terbiumactivated's Avatar
terbiumactivated
If I was near Albany or the Hudson I'd either look closer to the city for a shop or you will need to find an indy mechanic of good ability. This is just my opinion but I wouldn't bother with the dealer in CNY.
Old 04-27-2014 | 06:46 AM
DaveCarrera4's Avatar
DaveCarrera4
I think you are looking at a bit more, around $3000 or even higher. You are over $2000 in parts, especially if the Indy buys them.
2003 Carrera 4S Speed Yellow / 1955 356 Continental 1500 Rust Red
Old 04-27-2014 | 08:18 AM
e code's Avatar
e code
I've read a couple threads where people had it done for less. I would buy the parts myself to save a bit, but dont shops usually charge a fee for using your own parts?
Old 04-27-2014 | 11:42 AM
KoB's Avatar
KoB
I'd call R & D in Albany. No idea what they would charge, but they'll do a good job.
http://www.bavarianrocketscience.com/
Old 04-28-2014 | 12:25 AM
e code's Avatar
e code
That's what I was thinking. I am gonna make some calls tomorrow and see what I come up with. My Pelican Parts shopping cart has a spec clutch, aos, and LN IMS and its onlt 1,200. I would imagine it should be around 10-15 hours labor so hopefully it wont be too bad. Fingers crossed!
Old 04-28-2014 | 03:01 AM
sammyf's Avatar
sammyf
For your LN, I'd say get the pro kit ($799) if it's applicable... And budget for a brake/clutch fluid change if it's been a while and you will probably have to do at least one motor oil/filter change.
Old 04-28-2014 | 06:34 AM
DaveCarrera4
IIRC that dual row bearing takes a special installer, so budget for that as well if you go that route.
Old 04-28-2014 | 09:12 AM
e code's Avatar
e code
Well I was going try to find an indy that does these often, so they'd probably have the installer I'd imagine.
Old 04-28-2014 | 03:51 PM
fpb111's Avatar
fpb111
Maybe consider adding the DOF also?
http://tunersmotorsports.com/?page_id=103
Old 04-28-2014 | 06:41 PM
alpine003's Avatar
alpine003
Do you have a tip or manual? Take into account that Tip generally cost more as it's a bit more labor intensive.
Old 04-28-2014 | 07:09 PM
e code's Avatar
e code
Its a manual, I am considering the DOF actually. We shall see. Still getting quotes.
Old 04-28-2014 | 07:13 PM
5CHN3LL's Avatar
5CHN3LL
I'd ask if it's cool to bring your own parts before springing that on a shop. Walking in the door with your own box of stuff is not quite as blunt as just saying, "I think you're a crook and you're trying to rip me off," but it doesn't seem far off...
Quick Reply: Clutch is toast. Time for a clutch and LN IMSB/AOS/RMS
