996 Forum 1999-2005
Front Differential problem?
Old Apr 22, 2014 | 04:12 PM
johntorg's Avatar
johntorg
Default Front Differential problem?
A friend with a 2006 Tiptronic has a mid-pitch noise coming from the front end of his car. The noise gets louder with speed. Wheel bearings have been checked. Is there a way to definitively diagnose a problem with the front diff?
Old Apr 22, 2014 | 04:30 PM
Dennis C's Avatar
Dennis C
Rocky Mountain High
That question should be posted on the 997 forum. The 996 utilizes a mechanical AWD system with a viscous coupling. The 997 utilizes a computer controlled, electronic AWD system. I don't know how the 997 differential compares to the 996 differential.
FWIW, my front diff started making noise before it failed. It started as a subtle gear whine and eventually became louder, almost sounding like a slipping belt. Eventually it began to leak just prior to having it rebuilt.
Old Apr 22, 2014 | 06:16 PM
DaveCarrera4's Avatar
DaveCarrera4
There are bearings on the side of the diff where the half shafts hook up. I had one go bad. Made more noise when turning though.
2003 Carrera 4S Speed Yellow / 1955 356 Continental 1500 Rust Red
Old Apr 23, 2014 | 02:07 AM
johntorg's Avatar
johntorg
My apologies. This was meant for the Cayenne forum
Old Apr 23, 2014 | 12:18 PM
wwest's Avatar
wwest
It was only the later 997's (post 2010?) that didn't use the mostly NON-FUNCTIONAL VC system.
Old Apr 23, 2014 | 12:30 PM
Dennis C's Avatar
Dennis C
Rocky Mountain High
I thought the 997.1 was computer controlled. It was a viscous coupling also?
