Loose headlight assembly
Good morning..
For the past 2 weeks, my headlight assembly has intermittently loosens up. I have tightened it using the 5mm socket, will remain tight for a few :bumps" in the road, and then loosen up again..Would appreciate any input from the board.
Peter
Peter
Sounds like either one of your mounting studs are broken or bent or you didn't seat it correctly when installing. Take it out again and confirm all 4 studs are intact and straight.
