996 Forum 1999-2005
The tale of the $6500 Carrera
Old 02-01-2014, 05:37 PM
Vasir
Vasir's Avatar
pardon my noobiness, from the little research i did it looks like i have to drop the engine to get to this cam sensor?? thats not right, right?
Edit: nope. I got this. putting it on stands now.
Old 02-01-2014, 06:04 PM
Mhenry
Mhenry's Avatar
Vasir, you are the man. I am enjoying the DIY crowd taking on these cars.
Old 02-01-2014, 06:55 PM
fpb111
fpb111's Avatar
Did you listen to this video in post #9 in the other thread? Does the noise sound like "pool *****" clacking together?
Old 02-01-2014, 07:01 PM
speed rII
speed rII's Avatar
No need for stands, sensor 2 is on top of the right cyl head
Old 02-01-2014, 08:26 PM
Vasir
Vasir's Avatar
VID 00019 20101207 0956 Porsche IMS bearing sound - YouTube
no, not like that close, but no?. hard to describe.
Ffffff... If only I knew this 5 minutes ago. I spent 1 hour looking for my other jackstand when i gave up and used the ghetto cement block method instead, as you will see in the photo.
But thank you, this does make it easier!
figure its still good to go under it to investigate where the drip of oil is coming from.
Old 02-01-2014, 08:33 PM
Vasir
Vasir's Avatar
Took a recording of the sound:
Old 02-01-2014, 08:40 PM
fpb111
fpb111's Avatar
That sounds like dual row IMS bearing with cage failure on one side.
Ahsai
Ahsai's Avatar
Can you at least id which end of the engine the sound is coming from? When the cats break down inside, they could rattle like that, especially at idle.
Old 02-01-2014, 08:46 PM
Vasir
Vasir's Avatar
it def is coming from the where the trans connects... Ill start it up again and go under it to listen. maybe take a recording. In other news, the serpentine belt is toast.
Old 02-01-2014, 08:49 PM
Ahsai
Ahsai's Avatar
Only flywheel, IMSB, and clutch there. May need to drop the transmission to check further.
Old 02-01-2014, 08:51 PM
Vasir
Vasir's Avatar
Yep. Its coming from there. Engine's coming down.
But i hear it on the tranny side?
Old 02-01-2014, 08:53 PM
Ahsai
Ahsai's Avatar
I would take a bad trans over a bad engine any day. Good luck and let us know what you find.
Old 02-01-2014, 08:56 PM
Vasir
Vasir's Avatar
I hear it on the transmission side of things. Im torn on which to take down as a guesstimation first. If its the IMS i still have to take the transmission down, correct?
Video uploading now...
Old 02-01-2014, 09:00 PM
Vasir
Vasir's Avatar
Old 02-01-2014, 09:03 PM
fpb111
fpb111's Avatar
IMSB odds n ends for bedtime reading.
http://www.renntech.org/forums/topic...of#entry249245
http://www.renntech.org/forums/topic...of#entry243448
http://www.renntech.org/forums/topic...of#entry243192
Quick Reply: The tale of the $6500 Carrera
