Wheel/tire question...general
No need for that, we probably won't see anything. You may not see anything either, but if it's bad enough to hear you can feel it.
Park you car & turn the steering wheel all the way to one side. Hose off the tread surface & look for uneven wear especially the inside edge. Feel the tread from side to side. If it's flat & smooth from side to side check the rear tires.
I bet the inside edge is worn on 1 or more tires due to improper alignment.
Not sure how I missed this one.
I'll have the car for a few hours tomorrow and will investigate the tread.
Alignment crossed my mind too.
