996 Forum 1999-2005
18" x 11" Wheels, 51mm Offset??
Old 10-30-2013 | 08:31 PM
Nedster's Avatar
Nedster
Default 18" x 11" Wheels, 51mm Offset??
Will this work for rear on a narrow body 996?
By my calculations it would stick out about and inch more than stock 18" x 10" with 65mm offset (26.7mm to be exact). Probably too much What do you think?
Old 10-30-2013 | 09:00 PM
Kalashnikov's Avatar
Kalashnikov
Employ this tool.
http://acurazine.com/forums/tire_rim_calculator.php
Old 10-30-2013 | 09:51 PM
robo_porsche's Avatar
robo_porsche
I have 19" x 11" rims with ET60 on my 996 C2 2002. That is the absolute minimum ET you need with a rim that wide. You have 18" rims but I cannot see that would make any difference. I would say that the rims will not fit your car.
Robert
Old 10-31-2013 | 06:45 PM
white out's Avatar
white out
They will stick out a little with that offset (6mm more narrow than turbo wheels). If you lower the car, they will tuck under the fenders.
Old 10-31-2013 | 08:48 PM
MiamiC70's Avatar
MiamiC70
I ended up with Victor Innsbruck in 18 x 10.5 w/55mm offset as I felt the 11" stuck out too far.
Old 10-31-2013 | 11:04 PM
Randyg308's Avatar
Randyg308
the lower the number the wider hence 51 sounds like a wide body fitment,factory fitment for narrow body carerra is 18 inch x 10 wheel with a 65et.although i believe gt3 is slightly diff.
Quick Reply: 18" x 11" Wheels, 51mm Offset??
