996 Forum 1999-2005
Harness Bar
Old Jul 15, 2003 | 08:54 PM
Mike in CA's Avatar
Mike in CA
Default Harness Bar
I want to install a Brey Krause R1030 harness bar in my car. Their web site says the bar can be installed "without damaging the car in any way" but at the very least it appears that holes must be cut (or slits made) in the carpet to access the mounting points over the rear shock towers, or the carpet must be removed completely. Does anyone know of a source for factory carpet that I could modify so that I could save my original piece if I ever sell my car (god forbid). Or, I'm open to other suggestions....... TIA.
Old Jul 16, 2003 | 04:33 AM
Alon's Avatar
Alon
I think that those slits already exist, no?
Old Jul 16, 2003 | 05:25 AM
rdstemler's Avatar
rdstemler
I had to/decided to cut slits into my carpet, but it does hide the bolt heads and attachment hardware. I suppose I'll have to buy a new carpeted trim piece when I sell/trade the car but it looks pretty clean when the bar is not installed. I can attach the bar for the track in less then 20 minutes.
Old Jul 16, 2003 | 06:43 AM
Karl S's Avatar
Karl S
Mike,
You can either remove the carpet piece that covers the shock towers or cut it. I decided to cut mine, so I ordered a new one from the dealer in order to have an uncut one to put back in the car if I wanted to sell it.
Karl
Old Jul 16, 2003 | 07:38 AM
Mike in CA's Avatar
Mike in CA
Not in my carpet....
Old Jul 16, 2003 | 07:48 AM
Mike in CA's Avatar
Mike in CA
Originally posted by Karl S
Mike,
Karl
Thanks Karl, I'll probably do the same as you did. My OEM carpet is attached (glued?) to a large piece of sound insulating foam that spans the area between the two shock towers. I was hoping to get a simple section of carpet to cut and use with the bar installation and save the more expensive carpet/foam piece to put back in the car. Guess I'll call the dealer and see how much they will gouge me for a replacement factory part.
Old Jul 16, 2003 | 08:54 AM
Mike in CA's Avatar
Mike in CA
Karl,
Another question for you. What do you think of the Brey Krause harness truss bar? A bit cheaper and less obtrusive than the R1030. Drawbacks?
http://www.bkauto.com/porsche/r1025.php
Old Jul 16, 2003 | 09:07 AM
KPV's Avatar
KPV
Mike in CA,
It is only for 993 and earlier cars. I looked into it because it is pretty slick. The problem is the factory sliding seat beat shoulder mounts that the truss uses for anchorage.
Old Jul 16, 2003 | 09:15 AM
Mike in CA's Avatar
Mike in CA
Thanks Ken. The ad says "fits all 911's 69-present" but I guess they haven't updated the copy for a while.
Old Jul 16, 2003 | 04:00 PM
Viken's Avatar
Viken
Keeper of the Truth
Maybe, they don't consider the 996 a 911? Just kidding...
Old Jul 16, 2003 | 06:10 PM
Mike in CA's Avatar
Mike in CA
Viken, Viken, Viken...........
