Cross-drilled rotors can't be turned????
I'm getting down to thin pads, and had the tech check them out. They are still good for several track miles, but getting close to replacement. He also stated that there is quite a glaze on the rotors, and that he "strongly" recommends replacing the rotors as well. Says cross-drilled rotors can not be turned. True???? If so, we are talking buckoo bucks here. Probably eat up my GT3 seat or PSE budget allotment, maybe both.
Well, according to the Porsche Tech Manual... Yes, they can be machined.
Here are the specs:
Brake disc thickness, new -- front 28 mm, rear 24 mm
Minimum brake disc thickness after machining* -- front 26.6 mm, rear 22.6 mm (* The brake disc must only be reworked symmetrically, i.e. from both sides evenly.)
Brake disc wear limit -- front 26.0 mm, rear 22.0 mm
Peak-to-valley surface roughness of the brake disc after machining, max. -- 0.006 mm
Thickness tolerance of the brake discs, max. -- 0.02 mm
Lateral runout of the brake disc, max. -- 0.03 mm
Lateral runout of the wheel hub, max. -- 0.03 mm
Lateral runout of the brake disc when installed, max. -- 0.06 mm
Here are the specs:
mic = micrometer
I read a post on team.net's vintage racer forum that asked this question. According to those who answered, it is no problem to turn a cross-drilled (or Porsche's 'cross-cast') rotor on a standard auto machine shop brake rotor lathe. One writer got this info from "Scott Bethke at Brake Materials".
I replaced the four rotors on my 996 after they got cooked at a DE event. They should not use up your seat or exhaust budget... only half of it. <img border="0" title="" alt="[Wink]" src="wink.gif" />
Can't turn perforated rotors??? Whew - who dreamed that one up?
Take a close look @ your rotors. Notice that the "outside" edge of each perforation is nicely chamfered? That's there for two reasons: First, to reduce the chance of a pad edge catching, and Second, to allow for machining!
If you dig around, you can find some perforated rotors without this bevelling. Those rotors are extremely difficult to turn.
J
J
Glazed rotors are generally a result of overheating. There are two things you can do to prevent this in the future.
One get a front brake cooling kit. The best is the ducts that are used on the Cup and RS cars. Parts are available from PMNA but some cutting of the fender liners is required. The other option is an aftermarket cooling kit from CarGraphic, FVD, or one of the other tuners.
Second, keep the holes clean. Periodically use a punch or screwdriver and clean the brake dust out of the holes. This will allow the rotors to run cooler.
Most dealers don't turn rotors but you may find a brake specialty shop that has the right equipment and the skill to do this job. New front rotors should be about $200 per.
Karl
Karl
Thanks for the replies, all. It seems my particular Porsche serviceman either does not do machining, or does not want my specific rotors machined for one reason or another.
Karl S, thanks for the heads up on how to prevent this in the future. Will definitely look into cooling kits. Hope your GT3 comes out to you soon!
Palting -- When I was looking for a car, i spoke with a number of Porsche Service people about the brakes. Positions ranged from, we change the pads and rotors at the same time (no exceptions) to we change the rotors when they need to be changed.
I dont know for a fact, but I would guess Service Departments make a decision one way or another but that they don't have the machining capabilities.
Talked to the service GM. Thought I'd give an update to thank those that responded.
The rotors are quite worn. Not down to minimum, but close. There is no chamfering at the holes anymore, and there is a definite high ridge where the pads do not contact and are not worn. Whether I want to or not, it seems they DO need to be changed.
Another thing I picked up by talking to other car nuts. Pads only change is acceptable, but regarded as a cheapskate thing to do. I guess brakes is the last thing we all want to be a cheapskete on.
