To do list up to date
Thanks to information and inspiration shared on this forum I am now up to date on my DIY list for the C2.
Oil change - first time as DIY in 6 years. No sediment in oil filter housing. No glitter in the filter at all. A few dark plastic bits about the size of the head of pin and I am not concerned with that. I don't want to tally how much money I wasted on dealer oil changes over the past 6 years, suffice it to say that this is now a permanent DIY for me.
New air filter - had one on the shelf and decided to check it, even though 5k miles ago the dealer said no need to change it until the 90K mile service, 81K miles on the clock now and it needed a filter for sure.
Motor mounts - done - almost too easy.
Shifting is absolutely fine now - dealer said I needed a new shifter, I have an OEM SSK and I am glad I didn't jump at their "offer" to replace the shifter.
Much better clutch action. Noticeable improvement in throttle response.
It was such a joy to drive that I had a difficult time coming back in.
Thanks again to all who post their knowledge and encouragement. I tend to be a tad too anxious when considering DIY on the Porsches, always afraid something will go south and cause bigger problems. But so far, just doing some reading in advance and working at a relaxed pace and things go well.
Also helps to be out of work as having less dollars seems to have resulted in having more sense.
Kc, I had issues with clutch action and shifting that was inconsistent. At times everything worked smooth and as it should, other times the clutch feel would vary from normal to somewhat stiff but after running at rpm's over 4,000 it would feel fine again. Shifter would feel sloppy and I'd have to "hunt" for gears, especially noticeable on downshifts. It was the inconsistency along with how things would normalize after running at higher rpm's that lead me to suspect it was either motor mounts or the trans mount. I went after the easier option first.
Clutch feel is now good and consistent, shifts are smoother and more precise.
The surprise here is how much better it seems to run, I thought it ran fine before but the improvement was immediately noticeable.
Interesting. PO of my car replaced the engine about 2,000 miles before I bought it with a used engine. He replaced a bunch of seals and the IMSB and basically the clutch too. But I wonder if he used the old motor mounts. I think my exhaust tips hang lower than they should, and I have some of the same symptoms you had. I've got a lift, so if it's really easy and inexpensive to swap them out, I may do it to see the difference.
I haven't looked to see if my clutch pedal assist spring has been removed, but from reading the threads on that mod, I think it's lost favor a bit. My clutch & shifting aren't bad, but could be better. I have a short shift kit in it. But despite that and a new clutch, my son's 951 still shifts a lot better than my 996.
It was so easy I would have felt bad if I paid so much as $1.00 to the dealer. I did it on the floor so if you have a lift you are way ahead of the game. My left exhaust tip was just tad lower than the right one. I bought the mounts from Pelican, it was less than $200.00 for both.
I was surprised when the dealer put a new motor in my C4S but did not replace the mounts even when I suggested it. Their take is that if they are not leaking then they are good. The C4S also has an OEM SSK but it shifts very smooth and the clutch feel is great.
Basic Sponsor
Good going John! Enjoy your C2
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Most of the normal DIY stuff on these cars is really pretty easy. Even when you get to the stuff like headlight switches and shifters.
Don't get me started on anything to do with the door switches. I hate them... all of them..
Today I must finally tackle a water pump replacement on my old pick up truck, I am already imagining busted bolts and knuckles along the way.
