Viken,
Thanks for the reply. Just to make sure I understand, when you say "USA" confirm your talking about the standard M030 or are you talking about the standard (read non M030) suspension?
Originally posted by 02 Blue C2 Thanks for the reply. Just to make sure I understand, when you say "USA" confirm your talking about the standard M030 or are you talking about the standard (read non M030) suspension?
USA alignment specs are the same for both standard and M030.
Factory alignment settings are just a baseline, they're not set in stone. Before my RoW M030 install, rear camber was 2.5 neg and fronts were 0. It's set this way by the factory to suit the lowest common denominator among Porsche drivers i.e. the ham-fisted idiot who will likely over-drive the car and get into trouble. My settings are now, rear: 1.5 degrees neg, front 1 degree neg. The balance now is good, it's a good compromise between street (low tire wear) and track needs (neutral handling).
Originally posted by fahren affair Factory alignment settings are just a baseline, they're not set in stone. Before my RoW M030 install, rear camber was 2.5 neg and fronts were 0. It's set this way by the factory to suit the lowest common denominator among Porsche drivers i.e. the ham-fisted idiot who will likely over-drive the car and get into trouble. My settings are now, rear: 1.5 degrees neg, front 1 degree neg. The balance now is good, it's a good compromise between street (low tire wear) and track needs (neutral handling).
That is not true. The factory wants to adhere to their specs per workshop manuals. If yours were off, and if they were set like that by the factory, it was a sure mistake. The 2.5 degree negative camber would chew-up the inner tread in a heartbeat if car is mostly driven on highways.
Loren,
Again you come through with the exact information needed, perfect!!!!
Sorry for all the questions, just trying to understand the basics. Of course it is even more interesting to be able to hear the real world experience on the effects of different settings.
Thanks,
Gary
Originally posted by 02 Blue C2 If you have access to the factory specs could you post them for all four corners for me? Do the specs only call out camber or do they speak about caster, toe-in and toe- out as well?
After all this talk I'm going for the ROW 30 on my C2 Cab. A bit off topic, but I am interested in what it will cost to have the ROW 30 install (less parts) and aligned by a dealer.
Originally posted by Viken That is not true. The factory wants to adhere to their specs per workshop manuals. If yours were off, and if they were set like that by the factory, it was a sure mistake. The 2.5 degree negative camber would chew-up the inner tread in a heartbeat if car is mostly driven on highways.
I stand corrected. i pulled the labor ticket from Andial, and it states 1.5 neg rear camber (2.5 after it was lowered and before realignment). I still contend that factory settings make the car 'safe' not fast. It's meant to 'dumb-down' the car for the widest audience of owners/drivers most of which will never track their cars or want to extract to most from it. My current alignment was based on past experience from 10-yrs of bmwcca DEs and suggestions from rennlisters.
Originally posted by fahren affair I still contend that factory settings make the car 'safe' not fast. It's meant to 'dumb-down' the car for the widest audience of owners/drivers most of which will never track their cars or want to extract to most from it.
Sure, no one is arguing that. Factory settings are nowhere near ideal for any performance driving other than straight line. I believe the original question was asking for the factory settings and not the ideal ones for a specific type of driving.
