996 Forum 1999-2005
MPH in center display?
Old 10-04-2013 | 01:48 PM
  #31
Cuda911's Avatar
Cuda911
No beep at 37. Although, a couple weeks ago, it beeped at some speed (musta been about 75 or so) and I have no idea why. It hasn't done that since, however.
Also, that speed beep thingy was lit up green in the picture above (just to the right of center on speedometer), but for some reason is not currently lit. I know there's a description of it somewhere in the owner's manual (I read that section of the manual quite some time ago, but have since forgotten it). I haven't bothered to look it up again, since I seem to recall that it doesn't look like a feature that is of any use to me.
Old 10-04-2013 | 02:00 PM
  #32
wucash's Avatar
wucash
That's not a speed beep thingy its cruise control on/off. if its on it means you can set cruise control. you change it with lower right stack.
The beep can be turned on and off. Maybe right now its set at 37mph but OFF, if you figured out how to turn it on it would beep at 37mph.
Old 10-04-2013 | 02:44 PM
  #33
Dennis C's Avatar
Dennis C
Rocky Mountain High
What you're seeing is the average speed.
You can go into the menu and modify the display to show whatever you prefer in the default setting. If you set it to your trip meter then you won't have to toggle through menus when you reset the mileage.
Old 10-04-2013 | 03:33 PM
  #34
Cuda911's Avatar
Cuda911
Yep, thanks, I'll do that! Much appreciated, all!
Quick Reply: MPH in center display?
