996 Forum 1999-2005
cabriolet - drivers side window issue
Old Sep 28, 2013 | 12:29 AM
otto06's Avatar
otto06
Default cabriolet - drivers side window issue
I just had the alternator and the battery done on my car and ever since - the drivers side window does not stay down when I close the door. When I pull the handle it lowers the usual amount but as soon as I let go to shut the door -the window returns to the all the way up position. This only happens when opening from the outside handle - and only about 75% of the time. It operates fine if I open the door from the inside handle.
Anyone have any tricks here or do I have a microswitch going bad somewhere?
O
Old Sep 29, 2013 | 04:58 PM
otto06's Avatar
otto06
bump. Any thoughts on this? Couldnt find anything on search.
Old Sep 29, 2013 | 05:20 PM
Adker's Avatar
Adker
Look at this thread. Using a screw driver to close the latch with the door open should show you which switch isn't working correctly.
https://rennlist.com/forums/996-foru...ht=door+switch
Old Sep 29, 2013 | 05:35 PM
golftime's Avatar
golftime
Just experienced the exact same problem. Turned out to be the door latch micro-switch.
Old Sep 30, 2013 | 03:07 AM
otto06's Avatar
otto06
Thanks! I suppose I should have searched door latch. To late for this weekend but I will get into it next.
