C4S Rear Badge Placement - Opinions wanted.
#47
![](https://dl.dropboxusercontent.com/u/7855063/forum_photos/porscheforums/Porsche_Logo-Warped.png)
Send me your email address via PM and I'll send you the file. You can take it to any sign shop to have them cut the vinyl. I got 5 of them cut out for $20.
#49
PM sent. Thank you
I created it myself after much trial and error with different sizes and such. The tricky part was getting the curve right since that rear reflector actually has a slight curve to it and isn't straight across.
#51
ok someone needs to confirm,if the turbo spoiler from the aerokit will fit on a c4s or not? i doubt they made one specific for the c4s...of course i could be wrong...thanks
#52
Here's a different angle shot of the rear for a better view of the spoiler.
![](https://dl.dropboxusercontent.com/u/7855063/forum_photos/porscheforums/Porsche911-4-reduced.jpg)
#53
Nope it will not. I've done extensive searching and reading on the topic searching for a wing for my C4S. There is a good thread over on 6 speed. A Google search for turbo spoiler on c4s will lead you to some links with side by side photos of a custom conversion.
#54
The panel above the deck lid that holds the third brake light on the C4S is wider than the turbo's panel. Because of this the C4S deck lid is shorter than the turbo. Ask me how I know:
![Name: c4s lid1.jpg
Size: 179.2 KB](https://rennlist.com/forums/attachments/996-forum/806644d1392481124-c4s-rear-badge-placement-opinions-wanted-c4s-lid1.jpg)
#55
Attachment 806644
Attachment 806644
#56
Here's a nice looking wing for the C4s IMO. I believe it is a TechArt Type I.
![Name: techart.jpg
Size: 52.5 KB](https://rennlist.com/forums/attachments/996-forum/806646d1392481765-c4s-rear-badge-placement-opinions-wanted-techart.jpg)
#57
Beyond the obvious size differences it would require major modifications on the underside of the deck lid due to different air box intakes and other obstacles. I'm not saying it can't be done but a ton of work would be required.
I have a spare turbo deck lid that I'm wanting to graft the lower portion of the C4S lid on to it to get the center reflector. It's on the back burner as I haven't found a used or damaged reflector at a reasonable price and I'm not going to buy a new one for an experiment as they are quite pricey.
If I ever do it I think I'd do what the OP did as the lettering looks awesome.
![Name: c4s lid2.jpg
Size: 295.8 KB](https://rennlist.com/forums/attachments/996-forum/806649d1392482337-c4s-rear-badge-placement-opinions-wanted-c4s-lid2.jpg)
#58
Note it does not replace the C4S decklid. It replaces the movable spoiler only.
There are some Gt3tek BetterBodies ? Clones of that rear spoiler bolt-on on ebay for <$800.
I really do like the OP black lettering.
#59
I found a 2005 Renntech.org post on a Turbo Wing conversion to the C4S. In this install you loose the C4 Reflector
http://www.renntech.org/forums/topic...on-my-c4s-cab/
#60
That I'd like to see. Do you have any links?
Attachment 806649
Attachment 806649
