Brake pad retainer bolt safety spring w/o buying entire kit?
Hey everyone,
I personally changed my brakes for the first time today, and didn't realize there was a little safety spring on the retainer bolt when I pounded it out. Any idea where I can get just the safety spring, or else am I ok without them? I found the retainer kit, but all I need is a pair of the little safety springs.
Retainer kit for $38:
http://www.pelicanparts.com/cgi-bin/...51-959-01-M100
Amazing how easy it is to change the pads once I got them unstuck from the vibration dampers, did the whole job in about an hour. Was able to use a screwdriver to unstick the dampers without taking the calipers off. Also installed the 997 shifter today, very nice upgrade.
Thanks,
Chris
Thanks,
Chris
Are you talking about the small cotter hairpin? (aka R-clip)
I'm not sure of the size, but there is nothing special about it... A good hardware store, "real" autoparts store, Grainger or McMaster-Carr should have them.
![](http://photos.smugmug.com/photos/i-TrtsDDF/0/O/i-TrtsDDF-O.jpg)
I definitely wouldn't run without them, but a conventional cotter pin or safety wire would also do a great job making sure that pin doesn't back out if you can't find an R-clip in the right size. Just a bit more work next time you change the brakes.
Looks like they might also be called 'hitch pins', can pick them up at Home Depot or Lowes, sounds like the 7/8" length works:
https://rennlist.com/forums/porsche-...rakes-wtf.html
The pins are called hairpin spring cotter pins. I had a friend give me the size closest to what Granger sells. The size is .059" wire dia and 1 1/8 long. I'm calling Granger tomorrow and order them (Item No. 2MVJ5). 100 ea for $8.09.
I will be putting on my track pads in a few week and will let you know the results.
