Just changed my gearbox oil to Motul Gear 300
Now it could be Porsche has issued some tech bulletin that overrides this but I have no knowledge of this. Check with your local Porsche dealer parts department to learn what parts numbers/fluids possibly even additives (if any) are recommended for your car.
There are (or were last time I checked) only two manual transmission fluids. One from Mobil (Mobilube something or other) and Shell Transaxle fluid. They are miscible so there's no need to worry about which is in the tranny/diff.
And thanks for the chart!
No issues with gearbox whine at all on my car. People complaining of that must have other issues lol.
My car is an all year daily diver and I run it below freezing temperatures. The low temperature viscosity was really important to me as I didn't want my car to shift like a Mack truck in the winter.
On another note, if the shift cables are adjusted or set on the "tight" side to begin with, it will contract just enough in the cold to make shifts a bit difficult until warmed up.
I recently readjusted my cables and shifting has improved quite a bit in the cold now. It still feels good in hot weather as well.
If you look at the spacing of the adjustment grooves, you can see they're separated by fractions of a millimeter for a reason. Even the most minor adjustments can have a noticeable effect, especially running an SSK.
Cosmo Kramer, thanks for the advice, I just refreshed my tranny with Motul 300 75W90 and what a difference!!!!!!!! My car was running fine without any noticeable problems. It is time to change the motor oil and thought that I would do the tranny also. MAN!!! what a difference with the Motul..... It drivers like a new car. The tranny shifts smooth as silk and it is as quiet as a church mouse
I don't know if others will have the same results, but I am very happy![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Just thought I'd share this with the group
Cityfisher (09-07-2020)
Hi All,
I am another happy user of Motul 300 75W90. I had Delvac in my tranni for 25 miles. Even in 65 degree weather, the car shifted very poorly until warmed up - then it shifted fine. But, that will not work for me or the car. So, I tried to buy the Porsche stuff from the dealer. They told me that they use a fully synthetic Mobil 75W90 fluid that they buy in bulk. So, I read this thread, looked at the chart that shows how similar the Motul numbers are to the Shell product (recommended by Porsche, which I could not find anywhere) and decided to go with Motul - which I got 3 miles from my house at a motorcycle shop. GREAT STUFF. Car shifts awesome from start up to shut down. Very happy with it. Thanks for the advice guys.
Ray
Ray
Hi All,
Ray
Ray
