Headlights aint workin
Bi Xenons it seems they have been hesitant to come on lately, but I wasn't sure if it was me not really paying attention,
Tonight they won't turn on at all.
Running lights work, Hi beams will work when I flash them, fog lights work, just the head lights don't both sides, any ideas?
2002, C2
2002, C2
Rocky Mountain High
Headlight switch. Easy DIY. Instructions on forum made it cheap. Trick to getting out old switch is pulling out handle to reveal hex wrench hole on bottom of switch handle, then unscrewing to remove handle.
It seems like this is a common problem.
I just replaced my headlight switch today, with success.
I had the same symptoms as some described above, all lights working except Xenons. They just kind of blinked and would not "ignite". All other lights worked.
The switch isn't really designed to be repairable, but if you're handy, you can crack it open, repair it, and glue the shell back together for essentially free.
