Metal in filter
Macster I tend to agree with you. I'm pretty certain that is what has happend. The car is running incredibly well and this is my first oil change post DEs. Then my paranoia sets in and well there goes $2400 that I would have rather spent on my suspension. Better safe than sorry as they say. FWIW most of the metal didn't appear to be ferrous only about 3-4 small pieces. I read somewhere that a coating on the oil could cause it to appear ferrous when it's really not.
slopesider,
Don't get me wrong, but this is how my IMS started showing up. Just a little metal in the filter to begin with. I brushed it off as normal or chain tensioner, or whatever. Next oil change, I wasn't so sure. The 3rd oil change, and that was it. No more driving. I change my oil pretty often every 1K or 2 track events. I look at the filter every time. I'd shorten your oil change interval just to double check. If it is clean, then it maybe it's just be normal shedding. If it gets glittery, then it's time to take steps. IMS is ferrous and magnetic. Glitter will appear black on the magnet. Apologize if this isn't the first time you've heard this. Good luck.
Either the metal is ferrous (or at least attracted to a magnet) or it is not.
Even if it is a tiny amount is not something to get all scared about.
Sure, caution is the order of the day and you have to do what you feel is right for you.
My course of action would to after the oil change run the engine at idle up to temp then remove the oil filter housing and repeat the examination of the oil filter element and oil from the housing.
If a magnet (used to have one at the tip of a knurled rod with a spring loaded blade the other end used to start small metal screws into their hole) run over the filter or stirred in the filter housing oil came out with metal stuff clinging to it... well, I'd be worried.
But if the magnet came out free of any metal...
Slopeslider, you have too little metallic debris on your oil filter to worry about. I had the same amount, maybe even a little more and spoke to the country service GM. He said our engines shed a little material and that is regarded as normal wear. He said it happened most often during start up. I still cut my filters at each oil change and those tiny bits are there every time. I'd worry for about 2" and move on with my life. You can do all the things suggested by the other contributors if they'd make you feel better. If it affects your sleep, install the Guardian Angel, magnetic drain plug or just take sleeping pills.
OK, ask yourself this. If a PPI revealed these metal bits in the filter and you were the potential buyer, would you still buy the car????
I wouldnt worry about it, I would take action, whatever is appropriate for your abilities. The OP is making the right choice since a 20K engine is at stake and it needs the IMSB serviced anyway.
You guys that wont be buying his replacement engine should not be talking him out of addressing the issue.
Thanks for all of the input. Many valid points. Honestly, I felt like the whole IMSB thing was a bit overblown. That said seeing the metal in the filter admittedly got be a bit nervous. I figure I should be doing the IMSB anyway at some point and since I'm going out on the track this coming weekend, I would enjoy it a lot more not worrying about it. It will be interesting to see what shape the current bearing is in. The car goes in first thing tomorrow to start the teardown.
If I had read many of YOUR posts before buying my car and not read anyone else's and not done a lot of other research I probably would not have bought my car. I would have been erroneously led to believe it is an overpriced POS that has ridiculous parts and service costs and at risk of becoming a lawn ornament at any time. In the end I am glad that did not happen, I love my car and believe the parts and service costs are reasonable and/or cheaper than some other cars if you take the time to not just go to the dealer for everything. (Just like most other brands).
Sounds like the OP found what he found and has decided to take care of the IMS for his own peace of mind whether or not that is the (or even an) issue.
Slopeslider, please keep us informed of your IMSB change. If the Internet poll is to be believed, there's a 5% chance your bearing is on its way out. Keen to see pictures and comments of your bearing. Ask to keep it as paper weight! It's probably the most talked of bearing in the world.
Lets all calm down...KK is a zealot, we all know that by reading his posts. He's also able to do all the mechanical work on his car, and the inexpensive IMSB trial he is involved with is worthy of our collective attention. Still waiting on that parts list, but fairly well documented in another thread. The OP made an informed decision and based on what his gut told him to do. It will be interesting to hear if his OEM bearing is intact and in good shape. However, that may lead to another conclusion...
Well stopped by the shop this afternoon and the trany was out and you could definitely see a leak from the IMSB. Looks like I made the right call. To my chagrin while the car was up on the rack noticed my front right inside of my tire is shredded. Looks like i'm tire shopping today also. Any recommendations mixed street / track and about 6-8 DEs a year? The Michelin Pilot Sport Cups are sweet but not the $1400 price tag. Tire Rack recommended the Dunlap Derrzza Z2s. A little bit better on the cost at $1036.
Put on two new rears (Toyo Proxes 315x19" for $750, same as what was there before).
I had them road force balance all 4 wheels, and did a full 4 wheel alignment (mild aggressive setting), I would recommend the same for you SS.
