Spoiler Position indicator light?
Does anyone have a DIY for installing an indicator light to show if the retractable spoiler is up or down? I have searched quite a bit, and there used to be a DIY for this, but all of the links I have found lead nowhere.
I know there is a vendor on EBay that sells a kit, but I was looking for DIY instructions. I like a good project.
Basically, I have a spare indicator light on my dash that will be unused after I install my OBC (on board computer) switch. I'd like to have it do SOMETHING, and this seems like a fun, albeit superfluous project.
Has anyone done this? Do you know of a write-up?
Hi Frisbee,
I have the DIY and an extra light/switch/indicator........(if you or anyone out there is interested).....
I have not done it, but expect to do it soon. The stuff is at home (including the written DIY).....I do not have it in electronic form, but can send to you tomorrow...
If anyone out there lives in the Raleigh area and wants to do this mod, let's do it together.....I provide the beer, Rum, garage and tools !!
Ironman 140.6
I know this can be done because I performed this mod on my Boxster over a decade ago. The problem I have is it was so long ago I can't remember how I did it.
Driving the Boxster there is no way to see the spoiler while driving the car, but in the 996 all you need to do it look in the rear view mirror, so I never saw the point in doing the same mod on my 911.
If memory serves, I found the instructions on Porsche Pete's Boxster Board (now defunct). Be forwarned that to do this mod, you need to totally remove the instrument cluster. In other words it's not a simple mod for the faint of heart.
I think the instructions may be available still on Renntech.
Good luck.
Good luck.
This mod is very similar to the OBC enabling; You may want to do both at the same time (while you are there).........
I found the write ups......see attached.......
Good luck.
Good luck.
On my '99 Cab, I can't see the spoiler in the rear view mirror. Maybe because it's a cab, or maybe because I'm too short?
Surely someone must have the old DIY?
porschedog (09-12-2019)
Thanks for the info, but the write-up you attached for the Spoiler Indicator are the instructions for installing the ebay "kit". I was looking for the DIY instructions from scratch (no kit).
I think there is a small bit of electronics behind the switch needed, maybe a resistor or a relay. I can handle that if I understand how the mod works.
Still looking...
Ahhhhhh...if you are familiar with electronics, you will know what to do by studying/reviewing sheet number 97 of the 996 wiring diagram....specifically coordinates H to P and 74 to 80 of that sheet !!
As a former power electronics designer.....I thought of doing it my way also, but I decided to go the easy way.....the kit already exists...
[QUOTE=frisbee91;10484773]
On my '99 Cab, I can't see the spoiler in the rear view mirror. Maybe because it's a cab, or maybe because I'm too short?"
I have the same car, I am 6'3" and I cannot see it either !!
TopPorscheFan (09-08-2019)
I'm thinking I need to set up a latching circuit so my light goes on when the spoiler is fully extended, and off when fully retracted. Will these terminals give me a +12VDC signal, or just a closed contact to ground?
You are correct....it is #8....not sure what I was looking at when I picked 97 as the sheet...
I do not think you need a latching circuit, 'cause you already have the switching done by the "Drive Spoiler".....
#9 and #26 will give you a closed loop to ground (following the trace down to the drive spoiler, you can see that it goes to GP 8 - Ground Point 8, found in coordinate D167, sheet 17) ..... to be more specific, when spoiler is up, #9 goes to ground and #26 appears to "float"....when the spoiler is down, #26 goes to ground and #9 floats....
A simple circuit with an LED connecting the anode to a switched +12 will turn it on when extended (off when retracted).......or better yet, a dual color LED (common anode), red or green or orange when up, red or green or orange when down......do not forget to place a series resistor on the anode......
You could really get fancy and play with different combinations.....
...#9 and #26 will give you a closed loop to ground (following the trace down to the drive spoiler, you can see that it goes to GP 8 - Ground Point 8, found in coordinate D167, sheet 17) ..... to be more specific, when spoiler is up, #9 goes to ground and #26 appears to "float"....when the spoiler is down, #26 goes to ground and #9 floats....
Have I captured this correctly in my diagram below? What size resistor should I use?
