CEL under acceleration with #5 cylinder misfire
Hi all - been about 18 months since I left 996 land for 997 land. I still miss the camaraderie of this bunch, so I troll occasionally to see what's up.
A friend of mine and I were at lunch today and he's got a 2004 C4S. Under hard acceleration north of 3500 RPM his CEL light comes on and if he accelerates hard again it starts to flash. He's had it in to be looked at, but the techs are still researching the cause. The diagnostic readout indicates a misfire in cylinder 5, but the root cause has not been determined.
Has anyone else had this problem or know what the root cause might be?
Any and all help appreciated. Oh, btw, it is a Tiptronic.
Thanks much,
Kurt
Thanks much,
Kurt
Was it raining today or did he recently wash his car?
Due to the orientation of the intake, water can get in there. Cylinder sucks it in, engine misfires, CEL lights up like a Xmas tree...
If this was the case, clear the code and all will be well.
Check and see if the cats are plugged. I was getting random CELs for a while. Replaced all of the coils and still nothing.
Discovered my cats were clogged and that fixed my problem.
laz74: Weather was dry and car had not soaked at any time when it occurred.
fpena944: If it is the cats, why would the CEL readout be a misfire in a cylinder?
This is not a diagnosis just stating a possibility. I had a similar issue with my 2004 C2 a few years back. Code was for a misfire in cylinder 6 but I also had the "drive to workshop" warning. Turned out to be a lifter stuck on the high side for vario cam. In addition to the CEL it ran extremely rough.
Ahsai and Silotwo - great suggestions. Silotwo - he got the "drive to workshop/dealer" warning as well. Might be onto something here. Will check it out!
Thanks much.
Thanks much.
I never received any error codes except for the misfire.
One easy way to test this is to disconnect the cats and run the car for a bit. If it doesn't do it then you might be on to something.
