Coolant flashing+lines full of air
I bought my first Porsche august 2012, its a 1999 Carrera c2, it now has 103,000km on it. I came out last week to find a puddle of coolant underneath the car, so I took it to the shop and got the coolant tank replaced and put in new coolant (btw old coolant was **** yellow with tinge of green). They used the method where your revving car at 4k while adding coolant ect.
No success.. the coolant system is packed with air, I was told to try and drive it a bit to push the air out of the lines. (btw my bleeder valve comes up by itself within 5minutes of driving, if u slowly release cap there is tons of air and bleeder valve drops) - also within 10-15minutes of driving or so when the air really compresses a lot my engine will start to flutter its rpm's while idling, if I go release the air it will idle smooth til the pressure builds up again
- next day they tried again, service manual stated to elevate the rear of the car while putting in new coolant...+ doing the 4k revving, this also didn't work, I was told to try and drive it out again and have been releasing the air out of the cap few times a day, still nothing
coolant light is still flashing, still packed with air, and engines still fluttering its rpms when the pressure builds up
any suggestions?
any suggestions?
1) Buy this: UVIEW 550500 AirLift II Economy Cooling System Refiller : Amazon.com : Automotive
2) Enjoy life with no air in your coolant system.
-Shawn
-Shawn
You are going to destroy that engine doing what you are doing. The 3.4 engine is notorious for creating hot spots that crack the heads. Buy the UView and do it right. At least snap the bail up and leave it up until you get most of the air out.
iv been closely watching the temperature making sure it doesn't overheat, and it hasn't which is just further confusing since it should overheat with air in the system from what I was told?
The temp sensor only measures the coolant temp at one spot (after the radiator) in teh whole system. You could have localized overheat developed inside the engine block where the air pockets are and the temp sensor is never gonna read those...
It's the pre 99s that are air-cooled.
These newer ones need coolant.
I dropped by "hunter Porsche" shop to get his opinion an hour ago, He told me if its not over-heating than there is no air in the system and that it didn't matter if no vacuum tool was used it still works the same, but then he took off the cap and revved it and when releasing the gas pedal coolant started pouring out which he said isn't supposed to happen. he topped it off and it eventually stopped and he said it was fine and to try it (lights still flashing), I asked about the "fluttering" and he replied that he did not know the problem.
im not saying anyone's wrong here im just trying to figure out whats going on, 2 shops and both are confused
Coolant light is flashing and the shop still says it's fine. I think you should run from the shop....I think you should just start over by draining the coolant from the engine block, put the vacuum tool on, and refill.
thanks for all the replies guys
Other than the leak, were there any other issues before first shop did the "repair" work? If you believe the original shop to be competent, sounds like you should have went back to them FIRST. All parties involved sound clueless.
I still dont get why someone with no mechanical capability buys a 10+ year old high end sports car. I would educate myself about the 996 so you could at least ask relevant questions while speaking with a "real" Porsche technician if you can even find one.
