Is there any reason not to use ramps when changing engine mounts?
All the threads I've found say to use jackstands to hold the rear of the car up, is there a good reason not to use ramps instead? Is access a problem with ramps?
That's even better. If I put all my extensions together with a couple of knuckle joints maybe I can do it without even bending down...
^^ LOL !
I've been considering this DIY myself. How do you know if the mounts need to be replaced ? Is there a way, or do we just assume they need to be replaced after so many miles.
Passenger seat shakes when stopped, left side of engine hangs a bit lower (judging by exhaust outlets) and the shifting could be smoother (which is one of the things people seem to say is improved after changing - I think mine could be better so it's worth a try).
At 11-12 years old these parts take up a lot of the vibrations, it's probably time. And relatively cheap.
Thanks. I do have a slight difference on the left side as well judging by the tips, but no obvious shake. Looks like this will be a fun DIY Summer! Which mounts are you going with ?
I laid on my back used a long extension and 18 mm deep socket. The nut is really on there. One of mine the whole stud threaded out of the mount and I had to take the nut off of the stud in my vice later. Make sure you hit them with some PB Blaster before you start.
Did this a few weeks ago, very easy. As stated, shoot some PB Blaster on the bolts the night before. No need to raise the car, just support the engine under the mount right behind the pan.
the reason I used jacks while doing replacing motor mounts was the rest of my to-do items. I figured grouping the following tasks into one DIY made sense to put the car on jacks all around and remove tires:
Here is how it all started
1- i need swap from blizzaks to sumitomos. After all its may in Denver and finally stopped snowing
2- replace brake pads and flush fluid while the wheels are off
3-if the wheels are off might as well do the spark plugs because it is easier to reach in there.
4-while changing spark plugs remembered the new motor mounts that have been sitting on the bench since January.
Basic Sponsor
This is a great DIY project - takes very little time and effort and the benefit is pretty significant.
Here's our DIY article on the subject to guide you through the process:
Replacing your Engine Mounts
And the product's page within our catalog:
996 Engine Mounts
Mark / Pelican Parts
996 Engine Mounts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
