Is there any reason not to use ramps when changing engine mounts?
I used ramps, and a jack to support the engine. You definitely need an 18mm deep socket to get the bolts underneath. Other than that, very straightforward.
GL,
DS
GL,
DS
Ha Ha...
Nope, just love these cars. This is a really satisfying project, and the rewards are obvious. Makes it feel much younger. And don't we all need that?
Basic Sponsor
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
The car felt somewhat tighter during the drive to work this morning. Both mount's elastomeric rubbers had elongated by about 5 mm - a bit less than expected after 13 yrs and 143k kms. Used Rein's mounts as replacement - same as Pelican but purchased at a Vancouver indie.
Doing it again, I would replace both 18-mm flange nuts as well with new hardware to make it an easier dismount next time.
I did mine a few weeks ago. I just placed a plank under each wheel to give me a few extra inches to work with and it was quicker than using jack stands.
As everyone else indicated, replacing the mounts was straightforward. Since the filter box has to be removed it was a good time to spray-clean my MAF. I also sprayed the dust out of the SAI motor since it was out anyway.
I went with the RSS semi-solid engine mounts. They were double the price of the stock mounts but were still pretty cheap. They look great (FWIW) and should wear better than the stock ones. The car is definitely tighter and the increased noise in the cabin makes the experience a little more what I was expecting from a 911 :-)
Finally got around to doing the mounts today. Waited for the 4year old to take a nap, set the 6 year old up with Spongebob, backed the car on the ramps and started. I literally spent more time finding the correct tools than I did wrenching on the car. I found it easiest to complete one side at a time, figured that would minimize any engine movement while the jack was supporting it, then did the final tightening once both were in. Worked like a charm.
Seat vibration is virtually gone, and the shifting has improved SIGNIFICANTLY with much smoother engagements and less "clunkiness". Left exhaust outlet still hanging a bit lower than the right one though, will have to crawl back under and see how to adjust at a later date (tomorrow's nap time maybe)
I just got the regular mounts from Pelican, very happy with the improvement. Comparing them the old ones were extended by about 1/4" compared to the new ones.
X2 I feel dumb for not having done this sooner. Very easy, relatively cheap, and huge driving experience improvement. I hit the nuts with some PB blaster 1 week before while I was changing my oil, then again on the day I installed the new mounts. Still took a breaker bar to get them off, but not too difficult. I put the car on ramps for room to crawl under, then used a floor jack to support the engine.
