996 Forum 1999-2005
warning light
Old May 1, 2013 | 08:05 PM
zabuch's Avatar
zabuch
Default warning light
Iam getting an intermittent oil icon on dash then it goes away and oil pressure comes back anyone have this happen
Old May 1, 2013 | 08:27 PM
Ahsai's Avatar
Ahsai
Does the oil pressure drop to 0 momentarily? Most likely your oil pressure sender acting up. Extremely common problem and covered here many times. Mine go about every 25k miles.
Old May 1, 2013 | 08:31 PM
zabuch's Avatar
zabuch
thanks AHSAI i will look in to replacing is there a DIY link
Old May 1, 2013 | 08:33 PM
Ahsai's Avatar
Ahsai
A few diy links if you search. You need a crow foot wrench (19mm I think but pls check), a long extension and a ratchet. Go from the bottom right wheel well with wheel removed.
Old May 1, 2013 | 08:53 PM
zabuch's Avatar
zabuch
thanks ahsai
