C4S Rocker panel?
C4S Rocker panel?
I'm looking, but I can't find a part number for the passenger side rocker panel for my 04 C4S.
Someone decided to kick a large chunk of built up snow/ice from the wheel wells and basically shatter a huge chunk of plastic rocker material from the back left side
Can anyone help me find this part?
thanks
sean
thanks
sean
thanks
sean
thanks
sean
Check here...Gaudin Parts Online
For what it's worth, I recently purchased stuff from them and not only were they very helpful and responsive to my inquiries, they were also the least expensive resource for OEM parts that I found.
I hope this helps.
-Eric
Porsche P/N is 996 559 984 02 (G2X Primer) Porsche lists it as Sill but it is the right Rocker Panel. Left side is 983 02. Took me a little while but I found a pair of OEM sills on Ebay, new in the box for 200.00. I think the dealer gets about 500 each!!!
Cheers, Tom
Cheers, Tom
Yep, I think we both knew what you meant. This link should get you closer: http://www.gaudinporscheparts.com/pa...agramCallOut=2
It's #2 in the picture below.
I would just call the dealer to make sure you get the right part for the 4S. I'm not sure if it is the same part on the C4 and C4S.
-Eric
-Eric
ok, thanks. The listing says it's an Aerokit part, "GT3 look" so I didn't think it was the same as the stock C4S or Turbo piece.
Any tips on removal/installation?
The rocker trim piece itself comes off very easily...just a bunch of torx screws (T25?) and clips. If you have a trim tool or bone tool to separate the piece it would be helpful. Some of the clips push into rubber grommets where the trim meets the metal just below the door. Be careful not to push those little rubber bits into the frame. It's easy to do -- don't ask. Getting them out is a real PITA unless you just pick up new ones. Installation and removal is actually quite easy though.
-Eric
