996 Forum 1999-2005
Relocated spoiler switch
Old Apr 15, 2013 | 06:49 PM
Eric C's Avatar
Eric C
Freakhead I used the targa switch too and it is also illuminated
Old Apr 16, 2013 | 01:30 AM
Freakhead's Avatar
Freakhead
Thanks! When I get switch it should be easy install. Just have to figure out where to tap into PSM for illumination.
Old Apr 16, 2013 | 01:34 AM
Freakhead's Avatar
Freakhead
Originally Posted by Cmanis
Yes, I thought the instructions were good that came with the switch. I wish I would have been more careful with the connectors behind the instrument cluster as I broke some of the bottom off. The plastic is THIN. If anyone else removes the colored connectors from behind the gauges there is a black tab which the instructions call a cam that you pull perpendicular to the connector (kind of like opening a beer can). Then the connector comes right out. I took the image off the switch because it was a sticker and did not like how it looked.
Like the beer can reference; instructions in my kind of language.
Disappointed about the sticker. Am fussy and would not like it either but do want a symbol. I probably will stick with OEM switch i ordered that doesn't have light but has graphic. Just need to gloss it for my interior.
Thanks all!
Old Apr 16, 2013 | 07:19 AM
Eric C's Avatar
Eric C
Freakhead I will provide picture on where tap on PSM.
Old Apr 16, 2013 | 01:55 PM
CabrioArtie's Avatar
CabrioArtie
I installed the switch in my horseshoe a couple of years ago, but what I like about this solution is, it tells you whether the spoiler is up/down and/or in motion.
I would love to add this functionality to my install. Does anyone know what needs to be done/wired to get this status LED?
Old Apr 16, 2013 | 01:57 PM
Eric C's Avatar
Eric C
I'm also looking for the indicator led wiring.
Old Apr 16, 2013 | 10:36 PM
Wausau 911's Avatar
Wausau 911
I started this project today, had all the stuff (5' wires, connectors, switch ect). Opened the horseshoe and I'll be damned if I could figure out where to push the 3 wires through. Spent way to much time trying to get the wires through even with a coat hanger, where I could feel them with my hand. Where did the rest of you gentlemen push them through?
Old Apr 16, 2013 | 10:49 PM
Eric C's Avatar
Eric C
If you are seated in the drivers seat there is a small panel by your right foot. On mine it is covered with leather. Just pull on it and it Will be easier to fish the wires. Pull from the far end towards you it is held in place by push pins not screws
Old Apr 17, 2013 | 01:03 AM
Freakhead's Avatar
Freakhead
Excellent!
Will be in Portland picking up switches by end of month, then hoping to get on this in May depending on lacrosse tournaments.
Old Apr 17, 2013 | 01:58 PM
Cmanis's Avatar
Cmanis
Wausau 911, I put the wires to the instrument cluster through a small hole far back and to the left as you shine a flashlight through where the horseshoe goes. I put the wire to the fuse box through a hole immediately to the left and close to front of the dash of where the horseshoe goes. That wire runs along the top of the panel described described above. Hope that helps.
Old Apr 17, 2013 | 07:01 PM
Wausau 911's Avatar
Wausau 911
Thx Cmanis, unfortunately I have to put the switch on the Rt side of the horseshoe due an Ipod jack occupying the blank on the left. I'll still try pulling the leather pad off and see if that route will work.
Old May 27, 2013 | 12:42 AM
bobs95's Avatar
bobs95
I'm doing this mod as well but ran into a problem. I'm installing the spoiler switch on the right side of the horseshoe (because I'm installing the garage door opener mod on the left side) but the short cable is too short to reach the gray connector on the instrument binnacle. I can splice extra wire into the cable assembly to make it reach but since no one else mentioned having to do this I'm wondering if I routed the cable the wrong way. What do you guys think?
Old May 27, 2013 | 06:09 PM
Dennis "N" SC's Avatar
Dennis "N" SC
Will this switch open and close the spoiler at any speed?
Old May 27, 2013 | 07:03 PM
bobs95's Avatar
bobs95
Yup. Also has a red LED that flashes when the spoiler is raising or lowering, and stays on when it's deployed.
Old May 27, 2013 | 07:37 PM
Dennis "N" SC
Thanks a lot for your quick response. I just ordered one and only 2 available now.
