996 Forum 1999-2005
Should I top up oil?
Old 04-06-2013, 09:23 PM
KrazyK
KrazyK's Avatar
That bearing doesnt look that low in the engine to be submerged (I assume while not running). Anyone verified this?
Old 04-06-2013, 11:20 PM
alpine003
alpine003's Avatar
Originally Posted by Imo000
Since the theory is that the oil leaks out of the bearing when the engine sits for a while, they keeping is submurged will stop this. It makes sense to me.
Question I was trying to ask is at what point does the oil no longer reach the IMS, 6,7,8 qts?
Old 04-07-2013, 03:34 AM
Frank996
Frank996's Avatar
Originally Posted by Sneaky Pete
Without getting into a oil thread I use fully synthetic and currently 5W-40. Alot of us use that weight but others will use 0-40 and ......
OK, thanks for your reply. I think I'll continue with 0W40 as this is what the car dealer recommended as well
Old 04-07-2013, 03:06 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I don't know but other might. Hopefully the will chime in.
Old 04-17-2013, 09:21 AM
Frank996
Frank996's Avatar
I have noticed that when I fire up the engine the oil indicator is 1-2 bars from being fully filled. After a little drive, it comes down to around the half way mark and after a little longer drive it shows as being 100% full.
I gather this is due to the oil temp etc, so back to my initial question, at what state of the car should I check if oil should be topped up or not? When cold, after a few min drive or after a longer drive?
Old 04-17-2013, 09:39 AM
DBJoe996
DBJoe996's Avatar
Received 1,188 Likes on 760 Posts
Per the Owners Manual:
"Vehicle is Level
Engine is switched off and at operating temperature
Let engine oil flow into the oil pan for a few minutes after the engine has stopped running"
I usually wait about 4-5 minutes and check with the dipstick. A quick check on a road trip is right after stopping, getting fuel and then checking oil level.
The oil level must in no case fall below the minimum or exceed the maximum oil level on the dipstick. Always check oil level with the dipstick...never trust completely the electronic oil level gauge! Engines consume oil...I always keep mine topped up to the maximum level on the dipstick, adding oil as necessary between oil changes. 99 C2 124,000 miles, daily driver, no problems.
Old 04-17-2013, 01:53 PM
Ahsai
Ahsai's Avatar
The most consistent way I found (and also many others) is to measure the oil from the dip stick in the morning before you turn on the engine. It's consistent because most oil would have drained back to the sump and the ambient temp does not affect the volume much. The oil level reading will be significantly higher if the oil is really hot e.g., after a hard drive and say 5 minutes after shut off.
Old 04-20-2013, 12:50 PM
Frank996
Frank996's Avatar
The "problem" I have with the dip stick is that
1) I can't see where the oil actually is on the dip stick as the oil is very clear golden and the "market" is that orange plastic thing at the end of the dip stick, and
2) Where on the orange marker should the oil reading correctly be?
Old 04-21-2013, 12:21 PM
Macster
Macster's Avatar
IIRC from my 02 Boxster's owners manual the oil level should be between the min and max lines on the dipstick tip.
Old 04-21-2013, 03:29 PM
ltusler
ltusler's Avatar
Place a paper towel in your left hand. Pull out the dipstick with your right hand. Place end of dipstick in paper towel. Fold paper towel over dipstick end and squeeze. Open paper towel remove dipstick. Observe markings. Replace dipstick in engine. Add oil as required. Repeat as required.
Old 04-21-2013, 08:52 PM
7500rpm
7500rpm's Avatar
Stop complaining Frank996. At least you've got a dipstick. Porsche cut cost and guess what they removed in the 997?
Old 04-21-2013, 09:01 PM
Ahsai
Ahsai's Avatar
http://www.renntech.org/forums/index...&attach_id=785
I keep it at the max mark but anywhere between min and max is fine too. 1.33 quart between min and max. Best is to take out dipstick, wipe it with paper towel, reinsert, remove it again and then read it from an angle. Oil will appear very shinny.
Old 04-22-2013, 04:07 AM
Frank996
Frank996's Avatar
Old 04-22-2013, 04:09 AM
Frank996
Frank996's Avatar
Thanks all for your replies... I'll give it another go
Old 04-22-2013, 04:57 PM
KrazyK
KrazyK's Avatar
I did. The bearing is in fact submerged in oil while engine is not running, I assume partially so while engine is running. It would make sense to keep the level at max.
Quick Reply: Should I top up oil?
