Low temp thermostat, coolant temp variation
#33
#34
Hmm, I've noticed none of those particular changes in my '02 C2 since I installed my low temp. It goes up to dead center 180 and stays there, except in stop & go on a warm day, where I am not using AC. Then it goes up to just touching the "0" of 180 until I get moving steady again and it goes back down. Alt volts are the same SAI behaves the same, etc. With the old T-stat in cold weather, I would get heat right away since the heater core is always in the loop, then blam! cold air from the heater when the t-stat opened. This does not happen, or is not at all noticeable with the new t-stat, so temp cycling was far worse with the old stat vs the new stat. The low temp stat should be I creasing efficiency by having more flow at a more constant temp vs the old stat.
The car runs great and the temp is nice an consistant. This is a daily driver that has seen 10 degrees (in the winter with snows on) and 100 degrees (in the dead of summer).
If anyone thinks the gauge is accurate I have some land to sell you.
Running a stat that opens sooner and that is fully open just a bit earlier than the OE stat is not the same as running without a stat........
#35
Naturally, I am NOT saying that all engines are doomed, or Porsche engineers didn't know what they were doing, yada, yada, yada. Only that real 996 engine professionals, with far more experience that everyone on these forums combined, have indeed noted and measured the scuffing, and localized hot spots on SOME of these engines, and how close to the edge the other engines are, no one may ever know. I prefer to keep my engine farther from that edge with this simple, effective improvement.
#36
These are the same people that have something to sell you. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
OTOH, if it came from an independent source with nothing to gain and the statistics backed it up in raw hard numbers, I'd be more inclined to actually do something about it(not saying I don't believe the theory however).
As for temps, one can get a rough idea with a $20 infrared temp gun these days, if anything to measure temp variations on the rubber hoses in different areas.
Once again I'm certainly not preaching for one or the other. Individuals have to do what makes them comfortable and what makes sense to them.
One can also debate on adding 3rd radiator for street applications too for manuals...
There will always be things to nit pick over and that's what makes it great IMO.
Being able to start a dialogue on these topics to address any perceived issues and /or compromises from the manufacturer and letting the individual decide if they want to address them based on their priorities, budget, comfort, and other constraints.
#37
+1..right on! Agree with you 100%. Just an informative dialogue. I see it as, them not selling anything, or they wouldn't make the articles available. It's not like the M96 engine is known for its bullet proof cooling, though, right?
#38
[QUOTE=alpine003;10353423]It's funny how we pick apart Porsche(maybe a snowball witch hunt from the IMS?) and try to re-engineer everything. I'm sure there are some improvements that can be made and some of them could be detrimental. However I also see several high mileage examples that have done just fine driving it as is the way it came from Stuttgart. That's my story and I'm sticking to it. I don't like to have stained lips from drinking Kool-aid.
Seems like the Porsche crowd sometimes wants that last 5-10% regardless just to have a peace of mind or some sense of security sometimes.
I'll side with the Porsche engineers on this one as if it was something they really felt was wrong to begin with, they would've changed it on their later models at least with no additional cost to them(just different spec t-stat).[/QUOTE]
Think so? 997 temp gauge.
#40
Often times things can get cloudy in how things are either interpreted or might get communicated in the process. During that, it begs the question on whether something is often really "needed" or "required" in actuality for all practical intents and purposes.
My wife for example gets her teeth cleaned and examined at least twice a year. I on the other hand haven't been to a dentist in 15 years and I have all my teeth still.
I think you will find debates even among mechanics if somehow we can all get all master techs together on this and many topics. But the reality is that many bricks and mortars type mechanics don't really get to voice their opinion to the world since they are not on the internet, hence the cloudy part that I was referring to.
One thing for sure, I think people should do things that make them comfortable regardless of what may by needed or not. That is the point I was trying to make.
#41
I'm having a lot temp t-stat installed now.
So it might be worse for the engine in the long run?
What sort of t-stat are used in the Cup Cars?
Seems like I can deal with the need for more frequently oil changes. That's within my control.
High temp engine wear less so.
p.s.
Low temp t-stat is sold on LNE's website. I'm sure one of their guys will chime in at some point.
Phew....for a second there at 5 years I thought I was the national record-holder for longest without a dentis's visit.
In my defense, I only brush with down strokes, use a tongue brush, antiseptic wash and finish with a flouride rinse. Never drink coffee or smoke. Need to work on the flossing habit...
p.s.
#42
Porsche hasn't been shy of sending out TSB's for all sorts of things. If this was really an issue, I'm sure we would've seen a TSB on it.
#43
That's the million dollar question, what constitutes a "high" temp within the context of this engine in particular?
Engine hot spot theory seem valid for earlier coolant flow to reduce but how many premature failures have we seen or are going to see from the results of it?
#44
well that's total failure, pretty smalll sliver of the whole for sure. But there must be other issues that can come up with running at highER temp.
particualrly for a car that's often driven in an urban setting and sits idling in traffic on a daily basis.
