3.4L engine rebuild
Former Vendor
No two builders are the same and no two engines are the same, or projects, or drivers.
Rick if it turns out to not be the IMS bearing let us know and maybe we can get one of the mods to fix the survey. Good luck on your build.
3.4 to 3.6 upgrade???
did you do a dyno pull from before to after? using LN parts, not including labor, it looks like about $4500+ upgrade.
Here's a clip of a dyno run after Jake did a Stage2 3.6 build on my '99...
1999 996 dyno run July 2012 - YouTube
Don't really see the point of this video as it adds nothing. Where are the dyno numbers or graph?
Just kidding. Nice car and engine but I don't think I would stand that close.
Former Vendor
I used to post dyno runs as videos, till the smart asses showed up.
