Help! Snapped bolt
Replaced water pump and tstat with no major issues. Refilled and have a small leak from the tstat housing. One bolt was not completely tightened ( I had a hard time getting it back in). I tightened it more and then the bolt snapped!
Any ideas how to get the remaining half back out? Thanks!!
Here is a better picture with the housing removed. You can see the half of the bolt that is still in there. I had a hard time getting this bolt in so im sure it will be very hard to screw back out. I tried getting a vice grip on the small part that is sticking out but could not get enough of a grip to turn it. Any ideas how to get this out?
Also I need a new bolt. Is this something that needs to come from Porsche ?
Have you tried to grab it with a pair of vice grips? I snapped off a bolt a while back and was able to grab it with some mini vice grips and get it out. With the head off there is not much torque on the bolt..
I don't remember which one, but one bolt is longer than the other, that could cause the leak, if it was put back in the wrong hole (insert joke here). And if you torqued down the long bolt in a spot that was only drilled out for a short one, then you could easily snap it. May want to check that out.
Good luck,
DS
Good luck,
DS
From your photo, the engine side mating surface still has old gasket material on it. That will most likely cause a leak if not completely cleaned up. You can use a copper brush or 500 sand paper to wet sand it.
Same applies to the thermostat housing side.
Try flattening two opposing sides with a Dremmel so a good vice grips can grip it better. Lots of penetrating oil & let sit a few hours or over night. Add heat from a torch then try it. If that doesn't work you'll need to drill it out. There are plenty of videos on youtube showing how to get bolts like this out, probably worth some time to check them out.
The bolt seized or bottomed out and significant torque was applied after this to break the bolt. It is really in there tight. Forget the easy out, they are very hard and brittle and it will break easier than the bolt did. Then you will be in a pinch.
Obtain some small cobalt drill bits. Use the smallest, maybe a 1/16 th, then drill consecutive larger sizes until you are left with a thin shell where the hole ID is the same as you'd used for a tap. Place the pump in place for a guide and retap the hole. Use lubricant and a bottoming tap. Alternately when the hole is fairly large, try a reverse cut bit to attempt unscrewing the bolt.
Another tip. In hard bolts I start with a tiny #60 bit at high speed and drill it as far as possible.
Buy a set of these, its the easiest way. You just drill a hole in the broken bolt and insert one of these. The last time I had to use them was with a very rusty broken bolt that had been there for years and it came out easy as hell.
