996 Forum 1999-2005
Replacement keys
Old Mar 28, 2013 | 09:42 PM
tomofva's Avatar
tomofva
Default Replacement keys
When I recently purchased my 996 it came with only one key. It looks like the dealer is the only option to have a new one programed? What about cutting the key? Has anyone here purchased keys from another source and had the dealer cut and program them? ..or is that like going to a restuarant and bring your own steak? If you had a key cut and programmed how much it it cost you?
Old Mar 28, 2013 | 10:00 PM
Mark I's Avatar
Mark I
Keyhead ~$120 @ Sunset Porsche, Blade cut to your digital photo (it works!) ~$20 Keysinthepost.com, programming @ dealer 1hr. labor ~$100. DO NOT buy a used keyhead/one without a code tag - your car cannot be programmed to accept it.
Old Mar 28, 2013 | 10:18 PM
tomofva's Avatar
tomofva
The key blade and the key head are two parts?
Old Mar 28, 2013 | 10:22 PM
Mark I's Avatar
Mark I
Yes, the blade snaps into the keyhead. Above procedure will save you ~200 bucks.
Old Mar 28, 2013 | 11:10 PM
One Nut's Avatar
One Nut
Ohhh my wife a ( miss placed ) her set when we were on vacation last year... going through the dealer it was almost 600$ I got it done by my local indy for around 240. The key ,fob & programing i was relieved.
Old Mar 28, 2013 | 11:21 PM
tomofva's Avatar
tomofva
what is an indy? A key regular key shop?
Old Mar 28, 2013 | 11:25 PM
Mark I's Avatar
Mark I
Independent Garage. But it's rare to find one that has a connection with a Porsche dealership that will supply the code info (that has to be retrieved from Porsche NA). One Nut was lucky (and probably has forgiven the wife by now).
Old Mar 28, 2013 | 11:38 PM
tomofva's Avatar
tomofva
I think I have the code on a document the previous owner supplied. Can someone use that to make a key?
Old Mar 28, 2013 | 11:51 PM
aviography's Avatar
aviography
The code you are referring to is probably the radio anti-theft code.....
Old Mar 28, 2013 | 11:53 PM
Mark I's Avatar
Mark I
Cutting the key blade is no problem...it's the code that is supplied with the replacement keyhead (transponder) that has to programmed into the car's computer along with a series of codes from Porsche with a special device (PIWIS). Ordinarily it has to be done by a dealer, but in rare instances by an indy with the right device and connections to a dealer. Take both keys along, the original has to confirmed as part of the process.
Old Mar 28, 2013 | 11:59 PM
fpb111's Avatar
fpb111
The car is programmed to the key head and the code for each head is different. The supplied code may be for the working key that you have.
When you go to have the new one programmed you must bring the working key so that they can match it with its code, that code has been previously programmed to the car and there are probably more than one stored in the car. If you don't do that you will have a new working key and an old worthless key head.
The head has an RFID pill, black pill "loose" in the head and a, 15? integer, transmitter code both have to be formally introduced to the car.
Old Mar 29, 2013 | 12:04 AM
tomofva's Avatar
tomofva
Here is the list of codes without the numbers. Is this useful?
Old Mar 29, 2013 | 12:07 AM
tomofva's Avatar
tomofva
I would love to scrap all the security in this thing and just have a key with a remote and no alarm at all. Has anyone ever done that?
Old Mar 29, 2013 | 12:09 AM
fpb111's Avatar
fpb111
Probably cost much more than just getting the new key.
New transmitter head with code
File Type: jpg
Old Mar 29, 2013 | 12:11 AM
fpb111's Avatar
fpb111
Looks like you have the transponder codes for three keys and transmitter codes for two. Makes sense. The valet key has no transmitter. Just transponder (pill)
