I just got the pic of the trunk and the tire is laying flat, as well, I called the dealer and they have it listed as carrera 4 as well. How can I attach pics to this with out http?
The round black thing in the middle with a (I believe) 10mm nut on each of the 4 corners is the access to the fuel tank. I believe this is also unique to C4s.
+1
But don't make an offer until they fix the "Breaks".
If the silver things are Brake calipers then they are probably OK.
Jack up one side, ensure the car is in 1st gear, and attempt to spin the front wheel. If it freewheels, C2. If you can feel the mechanical resistance of the front drive (or you see the rear wheel moving when you spin the front wheel), C4.
Since you won't have the e-brake on (to allow the rear wheel to turn) - please chock both wheels on the side you're not jacking.
If you jack from the rear jack point, this will be sufficient to lift that entire side of the car.
A much easier way would be to just look for a front diff and 1/2 shafts.
