996 Forum 1999-2005
Replacing cdr-210
Old 03-01-2013 | 09:07 PM
DTMiller's Avatar
DTMiller
Default Replacing cdr-210
Just ordered a replacement for the stock stereo. Crutchfield says I will have to run a wire to the fuse box so it comes on and goes off with the ignition. Anyone have any experience with that? If I don't run that wire will it just not go off unless I turn off the power switch to the radio or will it not work at all?
Sorry if this has been discussed to death, I searched but couldn't find this issue.
Old 03-01-2013 | 09:15 PM
nymart's Avatar
nymart
I tapped into the telephone prep connector wiring for mine as was suggested by many others...you should find a plug in the bottom of your console..
http://www.renntech.org/forums/topic...ery-connector/
TeamSadistic's Avatar
TeamSadistic
What year car is it?
Old 03-01-2013 | 09:16 PM
DTMiller's Avatar
DTMiller
Old 03-01-2013 | 09:49 PM
Gator996's Avatar
Gator996
When I ordered my new head unit from Crutchfield they sent me the harness. It was plug and play for my 2000. I didn't have to wire anything into the fuse box.
Old 03-01-2013 | 10:57 PM
DTMiller's Avatar
DTMiller
That's what I was expecting but the guy on the phone went out of his way to point this issue out. Guess I will find out when it comes. It will either work or it won't.
Old 03-01-2013 | 10:59 PM
mmahon04's Avatar
mmahon04
I have a 1999 as well.
Your current deck already has switched power going to it (otherwise, how would it be powering up?). Crutchfield should be providing the proper harnesses for it, in which case it is as simple as matching wire to appropriate wire.
For reference, I installed this unit here.
Old 03-04-2013 | 07:15 PM
DTMiller's Avatar
DTMiller
Update - other than yellow connects to red and vice versa per the instructions, plug and play. Don't know wtf crutchfield guy was talking about.
Old 03-08-2013 | 01:42 AM
Long Islander's Avatar
Long Islander
What radio did you get? Did you remember to do something about the little switch that causes the alarm to beep if the radio is removed?
Quick Reply: Replacing cdr-210
