996 Forum 1999-2005
Flashing Check Engine Light
Old Feb 15, 2013 | 02:47 AM
uswrnk54's Avatar
uswrnk54
Default Flashing Check Engine Light
Got home tonight from a spirited drive. When I slowed down my check engine light started to flash. I parked the car outside. About 20 minutes later I started the car again and pulled it into the garage. The check engine light did not flash at that time.
The only diagnostics I've done is check the oil level, which is fine. Was my car just telling me "nice drivin' Tex"?
Old Feb 15, 2013 | 03:01 AM
Ahsai's Avatar
Ahsai
You need to use a scanner (a generic OBDII will do) to retrieve the code(s) and go from there. Also, if the CEL is flashing, it means you will damage the cats if keep driving. Let us know what you find.
Old Feb 15, 2013 | 09:17 AM
Ubermensch's Avatar
Ubermensch
I'm not aware of a blinking CEL suggesting anything in particular regarding your cats, but it does mean the car needs immediate attention and the fault it found isn't just something to drive around with. As Ahsai suggested, you need to pull the codes to figure out what's going on.
Old Feb 15, 2013 | 10:11 AM
jumper5836's Avatar
jumper5836
Flashing means severe catalytic converter damage and power loss will soon occur.
Old Feb 15, 2013 | 10:37 AM
LexVan's Avatar
LexVan
A flashing CEL means shutdown the engine, and call flatbed.
Old Feb 15, 2013 | 11:04 AM
rpm's S2's Avatar
rpm's S2
Exactly.
Old Feb 15, 2013 | 11:44 AM
morganabowen's Avatar
morganabowen
WOW!!!!! Pretty scary
Old Feb 15, 2013 | 11:46 AM
mmahon04's Avatar
mmahon04
A blinking CEL technically means the engine is misfiring. Damage to the cats can occur when the fuel in the cylinder is not ignited properly and a significant amount makes it into the exhaust system (where it may ignite and cause damage).
Old Feb 15, 2013 | 01:50 PM
Ahsai's Avatar
Ahsai
Guys, it's all in the owner's manual.
Old Feb 15, 2013 | 04:33 PM
white out's Avatar
white out
Unless Porsche doesn't follow OBDII standards, flashing CEL = misfire.
Old Feb 15, 2013 | 07:41 PM
mmahon04's Avatar
mmahon04
Thank you.
Old Feb 16, 2013 | 12:35 AM
KrazyK's Avatar
KrazyK
He didnt reply so it must have been CEF. Hope he posts an update.
Old Feb 16, 2013 | 01:32 AM
white out's Avatar
white out
An update that he has a misfire?
Old Feb 16, 2013 | 02:03 PM
KrazyK's Avatar
KrazyK
No, that it was CEF or not.
Old Feb 17, 2013 | 01:41 AM
uswrnk54's Avatar
uswrnk54
...sorry for the delay in response. No misfire, car runs perfect.
