Just bought a 99 Coupe
#51
Here is my 2007 Z06. Great car by the way.
Here is my wifes 2007 Convertible.
I have owned many cars in my life including a Boxster which was my first Porsche. I have owned a Ferrari, several Shelby Cobra replicas, miatas and about 10 Corvettes. I build kit cars as a hobby. I have built over 35 Factory Five Racing kit cars and also a few other brands. Not sure what is "fishy" about my love of cars.
Mike
Mike
#53
#54
How to replace the indicator and wiper switch assembly on a Porsche Boxster 986 or 996 model 911.
Tools Required:
8mm spanner
10mm spanner
T-30 Torx screwdriver bit with long thin extension
T-10 Torx bit
Philips Screwdriver
24mm Socket & Ratchet
Tipex, or paint and a permanent marker
Duct tape
1. Turn on ignition (to prevent alarm from going off) and disconnect negative terminal from battery. Cover the terminal to make sure it cannot contact the wire.
2. IMPORTANT! Wait for at least 10 minutes to allow the airbag system to discharge.
3. Fully extend the steering column.
4. Undo the 2 T-30 torx head screws behind the wheel. Turn the wheel to help access them.
5. Remove the airbag and carefully pry the connector off with a flat bladed screwdriver. Set the airbag aside. If removing for an extended period of time, Porsche recommend keeping in a locked container!
6. There was already paint on the shaft and nut from the factory, but if not, use paint and a permanent marker to mark the position of everything, so the wheel goes back on straight.
7. Undo the 24mm nut holding on the wheel.
8. Keeping the nut on a couple of threads (so you don't smack yourself in the face with the wheel) pull and wobble the wheel free. If stuck, a couple of taps with a rubber mallet should help.
9. Remove the nut and spring washer. Make another mark where the splines on the wheel meet the shaft. Then after disconnecting the electrical connectors remove the wheel.
10. Stick a bit of tape on the clock spring to stop everything moving around.
11. Remove 4 philips screws on the column faceplate, and 2 on the clock spring. There are a further 2 T-10 screws on the side on the column.
12. Carefully unclip the plastic parts, noting the routing of the wires inside. Move the clock spring to one side whilst connected. Remove the rubber stalk surrounds noting which is which.
13. The switch assembly is clamped around the shaft. Mark it's position on the shaft to make sure it goes back at the same depth, then loosen the 8mm bolt on the clamp.
14. Disconnect the 2 wiring plugs by pulling to the front of the car and remove the unit.
15. The new unit was supplied minus the wash/wipe insert (for cars with/without headlamp washers) so I swapped the old one over.
Reassembly is the reverse of dismantling.
The steering wheel nut torque setting is 34 ftlbs. It's just more than hand tight if you haven't got a torque wrench. The mark on the nut lets you know where it should be.
Porsche recommend fitting new airbag screws each time the seal is broken. Or just use a dab of blue loctite as they do to prevent them vibrating loose.
Once everything is back together reconnect the battery and enjoy working indicators again!
#55
It does not surprise me that you think the 996 feels slow compared to your Z06. A C6 Z06 is a beast of a car when it comes to acceleration and it will easily leave a 996 in its dust. However, the 996 is a far better sports car IMHO. The 996 feels more go kart like than the Z06(again IMO) and that, to me, is what a sports car is all about.
Also, remember the Z06 makes loads of HP and TQ down low in the rev range whereas the 996 has a "high strung" engine in comparison. To get the best performance out of your 996 you must keep the revs up and shift at or near the red line. The 996's motor needs to be revved past 5K RPM to really start producing serious power, unlike the Z06 which even at 2500 RPM is producing gobs of TQ.
#57
I guess I didnt get your point either because they are completely different cars. My 996 feels:
slow compared to my wifes GT,
no torque compared to my modded Cummins 5.9,
wont crawl over rocks or go through mud like my Rubicon,
has no room compared to my Dodge Ram work truck,
So what was your point again?
Joking aside, the 996 is unique around here and gets many comments where as newer Corvettes are all over and hardly get a 2nd glance. The vettes are nice too, just different.
