Best and worst mods you have tried
#32
Best: LN 3.8 rebore with nikasil plating and forged pistons. The car absolutley rips.... 300 TQ. / 330 HP to rear wheels.
H&R coilovers were a great upgrade as well. Corner speed and grip have improved dramatically with the lowered ride height, corner balance and aggressive alignment.
Worst: Tequip roll bar. The bar will not allow a tall driver to push seat back or recline. What a waste of time and money. Going to buy the new GMG bar instead.
#34
Best:
New motor mounts (well, not a mod i guess)
997 shifter
painted bumperettes
New simple JVC head unit
CD holder out- extra cubby in
Worst:
Removing the clutch pedal spring helper (it's back in)!
997 shifter
painted bumperettes
Worst:
#36
Best - Fister D's, I never get tired of the sound
2nd Best - iPod touch integration
Others -
Aluminum gauge rings
Mod to allow raising/lowering of Cab top while moving.
Swapped out pumpkins
Mod to make side markers blink with turn signals
A set of winter wheels/tires (Thanks for the link, Ivangene)
Silverstar lamps (not ultras, which I think are too bright)
Magnetic Oil plug (LNE)
Spin-On Oil Filter adapter (LNE)
X51 Oil Pan
Low Temp Thermostat
a couple of 3-letter items
Worst -
Paint modification by a 20 foot aluminum ladder
Bumper modification by a lawn chair (one of us was doing 80 mph)
Others -
X51 Oil Pan
Low Temp Thermostat
Worst -
#37
Cat bypass pipes. Love the sound, and feels like the car breathes much better on the freeway, but sweet suffering christ, the fumes make it impossible to drive with the windows down. I'm throwing the cats back on as soon as my clamps arrive from Pelican Parts.
Also changed out my K&N snorkel intake for a 997 3.8 box with a K&N drop in filter. K&N snorkel "cold air" filter was a bit too noisy for me, and now I'm getting used to hearing the sound of the engine again, instead of the sound of the intake.
Mods I've done that I'm happy with:
-Fabspeed Exhaust
-GT3 console delete
-GT3 steering wheel
-Alcantara shift boot and updated shift ****
-997 3.8 air box (just looks better, and easier to clean)
-19" wheels
-H&R Coilovers
-997 front end conversion
-997 style mirrors
-Ducktail engine lid
-Fabspeed Exhaust
-GT3 console delete
-GT3 steering wheel
-19" wheels
-H&R Coilovers
-997 style mirrors
#39
Best mod on my C2 was removing the clutch booster spring. It was easy and didn't cost anything and made the car much more enjoyable to drive all the time especially in stop and go heavy traffic.
https://rennlist.com/forums/996-foru...matically.html
Other mods I've liked are the PSE, heavier rear sway bar, grey marker lights, 911 rear emblem
#40
Best mod's:
PSE - love the sound and never turn it off (should have just gone for Fister D's but was worried about leaving home in the early hours which is the only time I close the valves)
2010 GT3 Shifter
Painted brake calipers red
Replaced pumpkins with clear side lights
Worst mod's - none so far.
2010 GT3 Shifter
#41
Took me a while to sort out but the Super Charger in place from TPC is frankly quite awesome. 100+HP is 'noticeable'.
Coil-Overs, make the car super tight, but are a bit bone-jarring.
TPC sway bars and stage 4 suspension are tunable and make the car handle more-so, on rails.
Fister-D exhaust - Sweet!
19 inch wheels also increased handling/tightness.
Next up, the iPad Mini integration for better sound and functionality. Link here.
#42
#43
I find this odd since any wear on this linkage will nullify much of the benefit of a new shifter console, I'm hearing conflicting information from local shops and wanted to check with you folks to see if your console had both linkages.
