If he removed the SAI wouldnt he have to have a program to erase the SAI codes each time the engine is started or the codes will just keep coming back? I still dont get what hes trying to do. The SAI does no hram or cost HP so what gives?
Basically the stock DME code has two parts on SAI:
1) To activate SAI at certain conditions (e.g,. cold start)
2) To verify that SAI is performing correctly once activated and flag codes/CEL if not
EVOMS claimed they reprogrammed the stock DME and removed parts 1) and 2) above so the new DME is not even trying to activate or verify the operation of SAI. So physically removing all the SAI parts should not affect anything or trip any CEL.
However, OP saw CEL tripped by SAI related codes, which means at least 2) was not removed, which conflicts with what EVOMS claimed.
