Can someone help me find that DIY radiator cleaning
I've searched for "radiator cleaning" and ten other keywords but cannot find the DIY article. I know it's here, I read it before!
When you have the front off you might want to re-route the front lid emergency release cable so you dont have to dig around under the drivers wing with a coat hanger for it should the main release cable ever snap. When you find the loop end of it, cut an half inch slit in the rubbery air scoop on the driver side and feed the loop through next to the air temp sensor. That way you can reach it easily. I did the same on the rear for the engine lid. Fed it through out near the rear bumper and wrapped it up out of the way. I can grab it if needed without having to fish about inside the rear lights..
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
