Suggested tire pressure with x74 Suspension?
For street use, same as factory recommendation. IIRC, they are: 36 psi front, 44 psi rear, measured on "cold" tires. Changing suspension doesn't drive a change in tire pressures.
Setting tire pressures for track use is an entirely different exercise, about which there are plenty of threads and even more opinions. I have not tracked my car so cannot offer any useful advice.
Try the it at factory setting and see if the rear dances around mid corner bumps. Although I have gt3 setup, there was no way I could drive at stock pressures. Currently happy at 34f/37r on v12s for street with my custom alignment settings.
I found stock 36/44 was way to harsh as someone said so I have been running 36/38 I guess I will start there and maybe drop fronts a bit as well.
32/36
one # per 100wt. plus 4# for motor +-
