G96 Transaxle Rebuild DIY
Hi
Im replacing my Pinionbearing in my gerabox on my 996 C2 -99 I have tear the box apart and going to start with taking the gears of the axle.
Is there anyone how have a DIY or a exploded view of the axle so I can figure out were I can put the press.
How big press do I need if a put the axle in the freezer firts and then heat the gears with gas torch. someone say 20-30 and someone says 80 ton! but that realy sound high
BR
E
BR
E
There are some threads on the board, but none of those have the exploded view's.
PM me your e-mail and I'l send you transmission .pdf.
Not sure if it's complete, but there is some info that you can use.
