x74 kit and p/n's
x74 kit and p/n's
Does anyone have the part numbers for the x74 suspension? I tried to look online but all the vendors list the product as NLA and thus there are no p/n's.
I know the kit comes with or without swaybars. And I believe there are 2 reinforcement plates as well. The shock/springs come assembled. Are there p/n's for the assemblies?
As far as I know (what Sunset told me), the X-73/74 kits are looked up and sold as individual parts based on the particular car (man trans, c4, etc). There is no "kit" part number.
S.
S.
Shock ABS 996-343-980-06
Support 996-343-980-08
Coil spring 996-343-980-07-504
Additional nut 996-343-980-09
Shock ABS 996-333-980-06
Coil spring 996-333-980-07-504
Additional nut 996-333-980-09
Shock SPA 911-333-511-00
Front Swaybar 996-343-701-21
Front Swaybar Bushings 996-343-792-12
Rear Swaybar 996-343-701-26
Rear Swaybar Bushings 996-333-792-25
Rear chassis braces ( reinforcement plates) (2, one for each side by tail lights)
R/R/ Reinforcement Brace 996-502-814-90-GRV
L/R Reinforcement Brace 996-502-813-90-GRV
Engine protection plate 996-107-981-00
+1 correct
You are not going to believe how this setup changes your car!!
Be ready for a bumpy ready feeling every ripple in the road, BUT, wow is it awesome from a handling perspective.
Pete
Pete
Prices from Sonnen:
So assuming you could actually source all the correct parts, maybe $4,800? I'm assuming the shock/spring prices are each and you need two of the each of the first eight items?
This renntech thread shows the superceded front spring/shock as correct...
- Shock ABS 996-343-980-06 (shows as superceded by 99634398020??, $400)
- Support 996-343-980-08 (shows as superceded by 99634398037??, $135)
- Coil spring 996-343-980-07-504 ($413)
- Additional nut 996-343-980-09 ($24)
- Shock ABS 996-333-980-06 ($480)
- Coil spring 996-333-980-07-504 ($627)
- Additional nut 996-333-980-09 (not found)
- Shock SPA 911-333-511-00 ($8)
- Front Swaybar 996-343-701-21 ($235)
- Front Swaybar Bushings 996-343-792-12 ($5)
- Rear Swaybar 996-343-701-26 (not found)
- Rear Swaybar Bushings 996-333-792-25 ($10)
- Rear chassis braces ( reinforcement plates) (2, one for each side by tail lights)
- R/R/ Reinforcement Brace 996-502-814-90-GRV ($44)
- L/R Reinforcement Brace 996-502-813-90-GRV ($44)
- Engine protection plate 996-107-981-00 ($86)
Three years ago when I did this there WAS a single X74 kit that had everything included (except the oil pan protection plate). It had a single part number, and Suncoast sold it. The box arrived with a Porsche sticker that said "Not for USA"... which I thought was funny.
But I just checked Suncoast's website and the kit is no longer listed. Perhaps it is NLA, but I would call them first to find out. If I remember correctly it was about $2300-2700 for the kit.
