996 Forum 1999-2005
Keyless Entry Stopped Working...
Old Dec 7, 2012 | 02:13 AM
996_911's Avatar
996_911
8th Gear
Default Keyless Entry Stopped Working...
My keyless entry stopped working....
Things I've done:
- Changed the battery
- Re-solder the button connections
- LED light works and blinks when pressed
What are other things can I do to diagnose this problem before going to a shop or stealership?
Thanks in advance.
Old Dec 7, 2012 | 03:19 AM
white99c2's Avatar
white99c2
You need a new key fob. They die and stop working. Buy a new one on eBay that is brand new and comes with the bar code tab. Take it to Porsche, they'll put your key into it and program it to your car. Do not buy one unless it has the bar code tab or it will be a waste of money. I bought a new one on eBay for $85.00 a few months ago, dealer charged me $65 to program it.
Old Dec 7, 2012 | 03:26 AM
996_911's Avatar
996_911
8th Gear
Okay I will look into that. I was in the merge of going aftermarket alarm...but I'd hate to have another big remote on my key chain.
Old Dec 7, 2012 | 03:29 AM
996_911's Avatar
996_911
8th Gear
Do I get the uncut key?
Old Dec 7, 2012 | 03:31 AM
996_911's Avatar
996_911
8th Gear
Can you supply a link from eBay? That way I know what I'm looking for. Thanks.
Old Dec 7, 2012 | 10:14 AM
Van's Avatar
Van
It is likely the alarm "brain" in the car - I looked into replacing it, and when I saw the $1000+ price tag, I've decided to live with locking the doors manually with the key.
Old Dec 7, 2012 | 12:15 PM
yank_my_chain's Avatar
yank_my_chain
Do you have any more info on how you re-soldered the button connections? Mine recently stopped working but I can see where the button swith came off and needs to be reconnected.
Old Dec 7, 2012 | 10:59 PM
fpb111's Avatar
fpb111
Excellence issue 183, June 2010, pages 125-126. "Fob 4 Less- Fixing a modern Porsche key for less than $3".
Pictures, arrows, instructions, part numbers. (www.digikey.com, part #CKN9193CT-ND)
Old Dec 7, 2012 | 11:09 PM
fpb111's Avatar
fpb111
Things I've done:
Thanks in advance.
This from an answer on Renntech with the same problem, same repair attempts, same Q about Ebay. You should contact this guy maybe he found a good place to get a key head cheap.
http://www.renntech.org/forums/topic...ings-ive-done/
""Posted Today, 11:17 AM
http://www.ebay.com/...da1c900&vxp=mtr
http://www.ebay.com/...886dfe0&vxp=mtr
http://www.ebay.com/...d33bc2a&vxp=mtr
Contact Sunset Porsche they usually sell them for ~$130. Local dealer normally charges 1 hour labor to program. Bring any working keys with you they need them to make sure they don't delete a working key. If you only had one, buy two new transmitters and get them both programmed for same price."
Old Dec 8, 2012 | 06:12 AM
996_911's Avatar
996_911
8th Gear
This only apply if the key "led" does NOT light up, correct?
Old Dec 8, 2012 | 12:15 PM
fpb111's Avatar
fpb111
??Probably?? yank_my_chain could answer that.
If you want the remote to work you are going to have to have to breakdown and have a new one programmed. No amount of chanting incantations while dancing around the car holding the transmitter above your head will fix it.
That only works for the dealer while they dance around a fire built out of your Benjamins.
