Scratch on seat plate. Can it be fixed?
I have a 2000 996 with Savana leather interior. The car is in excellent condition except for a few very little nit pick things. The one that bothers me most is on left side of the drivers seat. There is a small scratch on the plastic (?) piece that the seat adjusters are on.
It looks like the previouse owner went to adjust the seat fowrard or backward and he scratched the Savana color off the plastic. It now shows the black plastic (?) under the Savana color. I'll see if I can get a pic of it tonight.
What can I do to fix it? Does anyone sell replacement plates? I'd even go to a brushed silver plate if that's all there is. There are other hints of silver in the car and I think it would match.
ST
ST
Clean the area with rubbing alcohol. Then use this kit: http://www.leatherrepairkits.com/porsche.htm
If you are very skilled you can get it to blend just using a brush. I got a $20 airbrush kit from habor freight to feather the color for perfect repair.
Looks like this is the part number:
996.613.719.01
And the cover is apparently integrated with the entire seat switch mechanism... So it is expensive. New is $515, used from dcAuto in Savannah Beige is $413.
http://dcauto.gotdns.com/illustration/index/186924939
I would contact your local dealer's service department and find out who they use for interior repair/recondition. That is probably an easy fix that the dealer can arrange for you. A good guy can airbrush the entire part for a very smooth, professional look that touch up stuff can't match. I just had the soft touch rubber on my BMW's M sport steering wheel refinished and was amazed at the result.
996.613.719.01
Anyone know how to remove the plastic seat adjuster panel from the seat?
I unscrewed the two screws and I can pull the bottom of the panel out a bit, but I can't completely separate the panel from the seat and I don't want to break anything.
