996 Forum 1999-2005
K&N intake and water ingress
Old 11-16-2012 | 12:35 PM
halik's Avatar
halik
Default K&N intake and water ingress
Hey guys,
what's the consensus on water ingress to the intake area for the K&N kit? Seems like there might be a risk of water getting through the grates.
Please keep out the omg your maf dies the day you order the kit comments.
Old 11-16-2012 | 01:49 PM
Capt. Obvious's Avatar
Capt. Obvious
Nothing to worry about. If you're in a situation where enough water is getting sucked up to damage the engine, you probably have a much larger problem on your hands than the intake sucking in water.
Old 11-16-2012 | 02:21 PM
halik's Avatar
halik
So something like a torrential downpour would be of no risk? The K&N kit had no top on it; I suppose I could add an extra shield of sort
Old 11-16-2012 | 03:34 PM
trapperdog's Avatar
trapperdog
The K&N has a sock like cover that goes over the filter element that repels water. I don't use it as I don't usually drive in the rain, and in my mind, it would restrict the improved air flow the filter supposedly gives you.
Old 11-16-2012 | 05:26 PM
Capt. Obvious
You're fine. Anything just short of completely submerging the intake is water is not going to hurt the car, nor cause it to inject enough water to cause any kind of damage.
I've had multiple cars over the years with vented hoods that had the filter exposed directly to rain/snow that I drove that way year round, and I live in Seattle.
Old 11-16-2012 | 11:58 PM
9964runner's Avatar
9964runner
next time you have the hood up, take a look at it, pretty much solid other than openings for the air intake and heat extraction fan.
Old 11-17-2012 | 10:00 PM
carcster88's Avatar
carcster88
I have never had an issue with K&N filters in over 20 years. Just my personal experience. I have one on my 996. It is the Fabspeed intake but pretty much a K&N filter.
Old 11-17-2012 | 10:29 PM
San Rensho's Avatar
San Rensho
OMG your MAF is going to die, as well as losing HP because you no longer have a cold air intake.
Old 11-18-2012 | 12:21 PM
Barn996's Avatar
Barn996
^ Uh oh...
Old 11-18-2012 | 02:21 PM
halik's Avatar
halik
My MAF died right when I put the intake into my shopping cart on amazon.
Old 11-18-2012 | 05:01 PM
jordanturbo's Avatar
jordanturbo
Cardigan Millionaire
I had a K&N in mine, never had a problem with it taking on water in the 6 months I had it installed and daily driven. But as most say I did have problems with my MAF, I would always get a MAF code thrown when the oil from the filter would gum up the sensor. Yes I cleaned the filter numerous times, I won't say K & N intakes are bad, the piping is alright, but I would highly suggest a dry AEM cone filter for the unit.
Old 11-19-2012 | 01:09 AM
geetee's Avatar
geetee
I'm sure you've heard or hurricane Sandy. My area got about 4 inches of rain that 1 day. Drove 1.5 hours through it without a hiccup. K&N kit with taco wing if that makes a difference.
Quick Reply: K&N intake and water ingress
