996 Forum 1999-2005
Should I lock cams to replace tensioners?
Old 11-15-2012, 01:21 PM
j-mann
j-mann's Avatar
Default Should I lock cams to replace tensioners?
I am planning to replace chain tensioners on my '01 3.4. Should i lock the cams in addition to locking the crank?
Old 11-15-2012, 01:24 PM
KrazyK
KrazyK's Avatar
Why wouldnt you? I would think you could use the excuse to buy more tools.
Old 11-15-2012, 01:35 PM
jumper5836
jumper5836's Avatar
Are you able to do this with out splitting the case?
Old 11-15-2012, 01:38 PM
KrazyK
KrazyK's Avatar
Yes you can. Easy.
Old 11-15-2012, 02:05 PM
DBJoe996
DBJoe996's Avatar
Received 1,104 Likes on 710 Posts
Lock the cams...they could turn with valve spring pressure when the chains are undone. Getting the timing correct again if they turn is something you never want to experience.
Quick Reply: Should I lock cams to replace tensioners?
