leak in front end...help!
My 1999 996 has a small leak under the front end. Not a lot of fluid but something isn't right. Figured if it was in the rear could be oil but the front I have no clue(new owner). The liquid is yellowish and slightly thick but haven't been able to get it to my indy to put on the lift and see exactly where it's coming from. Any ideas would help as I can't get the car to the mechanic until next week. Thanks.
Coolant, probably from a radiator or one of its fittings. Aside from gasoline, that's pretty much the only fluid in the front end (depending on where you start counting the "front").
Between now and when I get the car to the mechanic I don't want to drive it without re-filling what has been lost, no way to tell how much fluid is actually left in the system, is the coolant resevoir under the bonnet?
Rocky Mountain High
This car is a C4, right? If so, it could also be that your front differetial is leaking. If this is the case, the leak will look more like an oil leak and you'll see spots on the garage floor in the center, between the front wheels. If your front differential is leaking, then you could need anything from new seals to a differential rebuild.
Received 1,166 Likes
The coolant tank is in the engine compartment on the left side. I agree, a leak from the front of the car is probably coolant if it is ahead of the front wheels, thus a leaking coolant hose or radiator. If it were windshield fluid overfill, it would show up behind the front wheels. You should absolutely check your coolant level before driving the car, and all the other fluid levels as well. Check your owners manual for location of the various check points.
If it is differential fluid in my C4, the liquid is between the front wheels, can I add more fluid until I get the car to my indy? Would the car exhibit any symptoms if it required a differential rebuild as opposed to just replacing the seal?
Rocky Mountain High
Typically leaking is the first symptom of a differential problem. If you look under the car, you'll see differential fluid/oil on the underbelly of the car. If it's just a few spots on the floor and some oil on the bottom tray, you're probably fine driving it to your mechanic as is. If it's a substantial leak, you might consider getting it towed.
In my case, I started noticing a gear whine and some noises that sounded like a slipping belt coming from the front of the car, especially during downshifting and deceleration. By th time I got mine to the mechanic, the bearings were shot as well as the seals. I've heard of some people only having to replace the seals due to leaks without touching the bearings.
Also - FYI - Porsche considers the front differential to be a non-servicable part. If you do have a differential problem and you take the car to a dealer, they will most likely suggest that they entire front differential needs to be replaced. The part alone is ~$7K. If this is the case, you have other options. A good independent mechanic can rebuild the differential, or you can buy a used one from a Porsche salvage yard or possibly from a turbo owner who has converted his 996 turbo to RWD like a GT2.
Hopefully your issue is coolant rather than the front differential.
Rocky Mountain High
Differential oil looks similar to transmission fluid.
Take a sample of your coolant from the plastic coolant filler tank with the blue/black top in the left of the engine bay. Then drop it on the garage floor and compare. Its not poisoness and should taste sweet if you want to taste it. Mine is a yellowish color. If its so low that you cannot see the liquid, then it probably is coolant on the floor. For now simply top it up with water but no higher than half way up the filler tank. You hopefully have a leaking radiator or condensor or hose to either. There are two of each at either side of the front end. If you are a handy DIY guy then theres a video on youtube on how to remove the front end ffrom the 99 996 to clean the crap from between the radiators and condensor grills. Helps the cooling system from over heating plus you can check or change rads or condesors or hoses if the trouble lies there.
If an oil film appears on the surface of the water odds are it is diff fluid or possibly power steering fluid.
Do a proper check of the coolant level and the power steering fluid and while you're at it the brake fluid level tool
Based on what I was told the times a front diff needs replacing -- and it isn't often -- noise from the diff is the driver's complaint and the only symptom.
Sincerely,
Macster.
1 Post
Digging up an old thread; the other day (90 plus degrees) I noticed a liquid closer to the drivers front fender than the passenger side, but still pretty much middle. I tasted it and it wasn't sweet or anything, honestly looks just like water. It is close to the cabin, behind the front wheels. Didn't smell like anything, or taste like anything, like coolant or washer fluid would...any ideas? I'm thinking it is 100% water, but from where? To the best of my knowledge we didn't get any rain the few days I noticed so I doubt it is the drain from the sunroof.
