FACTORY PORSCHE 996 tt wing and trunk fitted on to 996 c2. finally finished.
How did you cut the sides and the bottom: what type of tool? Also, did you move the base for the latch, if so how? Any pics of the inside of the cut areas? I am in the process of doing the same mod's.
Thanks for any help!
familycar911, how did you get this to fit? I have a 1999 and I also have a perfect turboS wing, and I would love to fit it to my car. Can you maybe email me what you did? jzzzake@yahoo.com. Thanks! BTW amazing job, looks perfect
BTW his report of 8 hours of work may be on the low side.
I'm in the process of fitting the wing also. I've found you need to loosen the hinges on the trunk and spread them to the widest "setting" to get the lid to squeeze in. Also thinking of elongating the holes on the hinges to have the decklid sit higher on the back of the mounting area.
I haven't gotten to the latch striker but I bought a set of metal brackets to attempt to relocate the latch striker, bolting off an existing piece on the lower lid.
I've also fabbed brackets to bolt under the spoiler area. I don't plan to install the K&N in order to get the full hydraulic system to fit. Posted my K&N for sale.
I spent a full day working the lid and still only about 80% done.
