Oxygen sensor failure after water pump change?
When removing the cats to replace the water pump (or at any time), it's not that difficult to impact the O2 sensor and damage it because it sticks out prominently...
Captain Obvious
Super User
Super User
Not hard at all. Just unplug the connectors, un-screw the O2 sensor from the exhaust (near the cat) and then work backwards with the new sensor.
This stuff is easy and there really is no reason to pay someone else's husband to un-clip and un-screw something you can do with standard everyday tools.
All O2s fit a 22mm, but there are specific O2 sockets that should be used if the you don't wan to cut the old wire off. These sockets are around $10 and there are two different styles. If you are not planning on re using the old sensor, just cut the connector off and put the box end of the 22mm wrench on it. Once it's cracked loose, it should almost come out by hand. If there is a lot of resistance, go back and forth and use WD40 (or something similar).
ok great advice guys. as it happens, drove out of the garage this morning....and the light was no longer lit! -_- . Does that imply something was loose? tank of bad gas? ( i only use 94 oct). Or is this maybe a lucky reprieve? Oy.
My WAG is it is a temporary reprieve.
That it occurs suggests a marginal connection that is a sensor connector not fully inserted/secure in the mating wiring harness connector.
Have you been under the car with a bright light looking at the sensor or senors pinpointed by the error code(s)?
Look for any signs of the sensor being knocked about, finger prints or a real clean sensor (wiped off), wrench marks that suggest the thing was handled maybe removed to be "cleaned" or when installed possibly the wrong thread lube used.
Give a check of the connections and that the sensor wiring is routed correctly.
Unless the car was in the shop for months or you had to blow cobwebs away from the gas pump to fill up the last time I'm thinking bad gas is not likely.
Sincerely,
Macster.
Sincerely,
Macster.
So, weeks later, we get to the bottom of the CEL that popped up suddenly. The diagnosis is a faulty MAF sensor. I am told that this item has to be sourced from the factory in Germany (!!) Not sure why they can't just go to Pelican. They're giving me a $1500 estimate for fix. I will report.
TC
TC
TC
TC
Contact Kevin
https://rennlist.com/forums/members/1437-kevin.html
LOL...you can buy a MAF for ~$280 and install it in less than 5-minutes if you are a slow poke.
Contact Kevin
Contact Kevin
Thanks guys. Inadequacy is expensive.
