PSE/Gundo Hack on gemballa cans
Hi everyone
I've been reading up on a lot of posts but still haven't come across a post on somebody doing it on a non-stock muffler. I have Gemballa cans on now but they're not loud enough so im gona take them off and take it to a local shop to do the welds by the end of this week but as far as I can remember when I put them on it didn't have the caps like the stock cans where you weld the pipe. I've seen some pictures of people actually just welding a connector pipe in between the two pipes (inlet & outlet pipe on the can). Any thoughts if both ways work the same? I have 2003 996 c2
I finally found the time to take my mufflers to a local shop and get the PSE hack done. After debating on either 2 inch or 1.5 inch pipe i decided to go with the 1.5 inch pipe due to already having gemballa cans which are semi loud so with the 1.5 i got exactly what i was looking for. By far the best mod i have done so far.
Here is a nicer pic ivangene. They gave a choice for a test drive between the two when i went to pick up the car........i chose the car
Which one do you think is higher maintenance? Also the Car wont take half of everything down the road.
