996 Forum 1999-2005
Help car stalled & won't start
Old 09-11-2012, 02:01 AM
speed rII
speed rII's Avatar
Try to push the throttle full open and start. By doing this, ecu will stop the injectors and try to clear the flood.
It seem's thou, that you have no spark.
Get the ecu codes checked, there might be a problem, even when the cel is not on
Old 09-11-2012, 07:01 AM
Hurdigurdiman
Hurdigurdiman's Avatar
Originally Posted by 911mike99
1/4 tank gas gage said. I did add a half gallon gas from my Lawnmower can. The key feels normal. No lights came on that I seen. It just shut off. It tries to start for about a second and shuts off.
hope the fuel you added was 93 octane although one would think half a gallon added to already good gas would be ok. Did you add the lawn mower gas BEFORE or after it started to cut out on you? There is usually grass clippings around thed neck of a lawn mower gas can. Or you may have ran the tank very low and disturbed some **** in the tank which found its way to the carb. Especially with it being a high milage vehicle. There may be some crap in there moreso than a lower milage vehicle. Just a thought.
Old 09-11-2012, 08:34 AM
MJBird993
MJBird993's Avatar
I concur. Pull a spark plug wire, check to see if you have spark.
Someone suggested that this is a high mileage car. How do we know that? If it is and you do have spark, maybe the distributor is worn, or the crank sensor is bad.
Old 09-11-2012, 08:59 AM
Ubermensch
Ubermensch's Avatar
I agree it sounds like an electrical issue. What's it like when you try to start it? Any noise? Can you hear the starter trying to turn things over and it just doesn't?
PS-We don't have distributors.
Old 09-11-2012, 11:11 AM
Shark Attack
Shark Attack's Avatar
I had a VERY simular condition recently. The re-juv valve was sticking open and putting a vaccum on the fuel tank. take off the fuel cap, try to start and see what you get. It may toss you a CEL.
Old 09-11-2012, 11:55 AM
fpb111
fpb111's Avatar
Also consider:
http://www.renntech.org/forums/topic...ensor-removal/
Old 09-11-2012, 02:55 PM
MJBird993
MJBird993's Avatar
We did?
Hey, the last time I did anything more than change the oil on a Porsche it was a 993.
Old 09-12-2012, 07:13 AM
911mike99
911mike99's Avatar
When it first stalled. It did try to start for about a second. So I added about 1/2 gal. Of Lawnmower gas. Last night I added 2 more gallons of gas & no start. I did notice the antifreeze was 2 cups low in the overflow. I added Porsche antifreeze. Now it just turns over only. It has 86k miles on it.
Old 09-12-2012, 05:01 PM
TomF
TomF's Avatar
There is a TSB about the fact that the gauge is incapable of reading accurately below the 20l mark. In other words, if you add less than 20l, the gauge won't even register the difference. I would get a 5 gallon can of 93 octane and add it to your car. That way you know for sure that it is not a fuel-level issue.
+1 on the idea of leaving the fuel cap off and trying to start the car. If the evap valve or canister have failed, this should help.
Old 09-12-2012, 10:34 PM
911mike99
911mike99's Avatar
Ok Tom thanks for the advise. I'll add some more gas tomorrow.
Old 09-13-2012, 11:18 AM
SimonP5150
SimonP5150's Avatar
Go to Pep Boys and get a $10 OBD2 code reader and tell us if there are any codes.
Old 09-14-2012, 07:17 AM
911mike99
911mike99's Avatar
$10 for OBD2 code reader? Ya ok.
Old 09-14-2012, 12:36 PM
911mike99
911mike99's Avatar
Just got a obd2 code reader at advance auto (actron) When I get home later today I'll check for codes.
Old 09-14-2012, 08:24 PM
911mike99
911mike99's Avatar
No codes showed up. I unhooked the battery a couple times when trying to start. It might of reset the codes.
Old 09-18-2012, 03:30 PM
911mike99
911mike99's Avatar
It was the crank sensor.
Quick Reply: Help car stalled & won't start
