996 targa electrical problems
3rd Gear
A mates car has developed a problem with:
targa top not opening
rear blind stopped working
and Amp not providing any power
he has checked motor for Targa, replaced Battery
things affected point to ECU has anyone anything to suggest to aide his search for a fix?
Fuses all ok
car has :
Airbag failure message
targa won't open
no sound output from stereo
interior light staying on
boot/lid open message(even though they are closed)
car was jump started previously and is now draining battery overnight
Fuses all ok
car has :
targa won't open
Fuses all ok
car has :
targa won't open
Fuses all ok
car has :
targa won't open
First id remove battery and get it tested. Assuming battery checks ok you have a short somewhere that is draining battery. Could be fried ecu. From jumping but you could start to eliminate things by removing fuses one at a time from the circuits effected and watch battery voltage with mulimeter ... if that does not point to problem time to go to indie for better diagnosis ...
3rd Gear
To update
Replaced Targa ECU and normal service resumed.
Stereo was unrelated
and it still has the airbag warning light on the dash
bust the reset is all working again.
thanks for the help.
